hehe dongle. fatz doesn't need that he's already got one. it's not real big though so maybe another couldn't hurt? maybe that's the problem? dongle too small for good reception.
  • Replies 61
Yeah I can vouch for NextG wireless, i use one for work... Shitloads better than all of the others, in coverage and speed (I've tested 3, vodaphone and unwired). The only downside is cost, it's pretty expensive!! Like $89 for 1GB per month on a 24 month contract... ouch!
Well if its telstra we all know we arnt going to get a good deal.. prob be $1000 for the dongle, $90 a month for 2g and $100 a mb after that.
At least they have good returns for there stock holders, oh wait there stocks suck.
Thanks doof :D for everyone else www.iinet
you're right, it's not really cheap... but it is really good...
The dongle (hehe) can come free on a $80 plan (i think) below that you have to buy it... the series 7 (old) can be flashed with the new software to make it the same speed as the series 8's... So unless you wanna spend a huge amount, there's no point buying a damn expensive dongle...
hehe :laugh:
And that makes my day complete. LoL
All i seen was 'no home phone line'. If it helps,,,my home internet is T'd from the foxtel cable.
Telstra internet with wireless router
Telstra also does a wireless modem aswell.but the modem has to be T'd into the foxtel cable then
its wireless from modem to desktops/laptops.
The cheapest and easiest way will be to just get your phone line hooked up ($30/mth) and get a cheap 512k ADSL1 plan with someone like aaNet for $25/mth so all up about $55/mth which is only about $15/mth more than using unpredictable wireless.
No go with foxtel?
Also, Tivo is coming out soon,supposedly you can use it with your tv to access
the internet.
Your Tivo also needs an internet connection, so it's just passing the internet through to the TV from your ADSL/other connection :)
  • 1 month later...
fatz, did you ever get porn working at home? I just moved into a new place and getting the hook up. going with iinet in the end, and I noticed they have naked dsl now which means you not need phone line. they will give you the porn even without the phone. but I'm not sure how you will ring hot gossip without it? I gues you can use mobile.
now I have an actual question. where in sydney is cheap computer hardware retailers? I need to buy a new ADSL2 modem (with wireless router) and some other gear. leaning towards the billion 7300N. any suggestions gratefully received.
I wouldn't touch Billion mate, then again I wouldn't touch D-Link either, but that is just me.
Go for a Linksys.
well I've always been very keen on netgear.
a while ago when ADSL first hit the scene I had a billion ADSL mode/router and it was good. worked as it was supposed to. after about 4 years the power button broke, but I just taped it up and after that it was sweet until I upgraded.
then I tried a linksys, just wouldn't work with my config. tried a belkin, same problem and it was crap. then bought a netgear. easiest modem/router I have ever set-up. allowed my (then) out of the norm configuration and literally took maybe 2 mins to set-up.
I was very happy with it.
but I'm willing to look at linksys again. Can you suggest a comparable model that does the same stuff as that billion 7300N? cheersu. (^_^)
d-link works fine for me - setup around 3-4 wireless networks without a problem all been running for over 2yrs
Same here, I have a DSL504T & a dl524 running here, no probs.
To the OP, have you tried using satellite net connection? It cost A LOT though for speed thats not much better than ADSL.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
