hehe dongle. fatz doesn't need that he's already got one. it's not real big though so maybe another couldn't hurt? maybe that's the problem? dongle too small for good reception.
  • Replies 61
Yeah I can vouch for NextG wireless, i use one for work... Shitloads better than all of the others, in coverage and speed (I've tested 3, vodaphone and unwired). The only downside is cost, it's pretty expensive!! Like $89 for 1GB per month on a 24 month contract... ouch!
Well if its telstra we all know we arnt going to get a good deal.. prob be $1000 for the dongle, $90 a month for 2g and $100 a mb after that.
At least they have good returns for there stock holders, oh wait there stocks suck.
Thanks doof :D for everyone else www.iinet
you're right, it's not really cheap... but it is really good...
The dongle (hehe) can come free on a $80 plan (i think) below that you have to buy it... the series 7 (old) can be flashed with the new software to make it the same speed as the series 8's... So unless you wanna spend a huge amount, there's no point buying a damn expensive dongle...
hehe :laugh:
And that makes my day complete. LoL
All i seen was 'no home phone line'. If it helps,,,my home internet is T'd from the foxtel cable.
Telstra internet with wireless router
Telstra also does a wireless modem aswell.but the modem has to be T'd into the foxtel cable then
its wireless from modem to desktops/laptops.
The cheapest and easiest way will be to just get your phone line hooked up ($30/mth) and get a cheap 512k ADSL1 plan with someone like aaNet for $25/mth so all up about $55/mth which is only about $15/mth more than using unpredictable wireless.
No go with foxtel?
Also, Tivo is coming out soon,supposedly you can use it with your tv to access
the internet.
Your Tivo also needs an internet connection, so it's just passing the internet through to the TV from your ADSL/other connection :)
  • 1 month later...
fatz, did you ever get porn working at home? I just moved into a new place and getting the hook up. going with iinet in the end, and I noticed they have naked dsl now which means you not need phone line. they will give you the porn even without the phone. but I'm not sure how you will ring hot gossip without it? I gues you can use mobile.
now I have an actual question. where in sydney is cheap computer hardware retailers? I need to buy a new ADSL2 modem (with wireless router) and some other gear. leaning towards the billion 7300N. any suggestions gratefully received.
I wouldn't touch Billion mate, then again I wouldn't touch D-Link either, but that is just me.
Go for a Linksys.
well I've always been very keen on netgear.
a while ago when ADSL first hit the scene I had a billion ADSL mode/router and it was good. worked as it was supposed to. after about 4 years the power button broke, but I just taped it up and after that it was sweet until I upgraded.
then I tried a linksys, just wouldn't work with my config. tried a belkin, same problem and it was crap. then bought a netgear. easiest modem/router I have ever set-up. allowed my (then) out of the norm configuration and literally took maybe 2 mins to set-up.
I was very happy with it.
but I'm willing to look at linksys again. Can you suggest a comparable model that does the same stuff as that billion 7300N? cheersu. (^_^)
d-link works fine for me - setup around 3-4 wireless networks without a problem all been running for over 2yrs
Same here, I have a DSL504T & a dl524 running here, no probs.
To the OP, have you tried using satellite net connection? It cost A LOT though for speed thats not much better than ADSL.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
