Hey Guys,
Yeah i know there has been heaps of DYI tutes on painting rims but i thought i might just do one anyway. If it helps good if not... meh :)
So anyway painting the rims is a pretty easy job really but it just takes time, especially as i was doing my Autech 260RS BBS rims that have crap loads of spokes. Doing a set like 5 spokers would be much easier but the bigger the surface the easier it is to see blemishes and imperfections, so there is challenges with either project.
First of all you have to sort out your equipment first; here is what i used
Other Stuff
• About 2 or so cans of degreaser (i just used el'cheapo supercheap junk)
• Some soapy water, sponge (have no idea where u could get these complicated tools :down: )
• A really light grit sandpaper like 40, 80 about 4 or so sheets of each( hardware store, u know em)
• Masking Tape x 2 big rolls about 40mm wide (don’t get it too wide)
• Old news paper
Paint
The paint is pretty much going to make or break your project (apart from u doin a crap job) so it is worth you spending some money on good quality stuff otherwise it may look okay for a month but then it will chip, peel etc etc. So if you had ideas of this project costing you $20 think again. Essentially what you will need is Primer, Paint and Clear coat.
Where to buy your paint, well you have a few options there is paint suppliers like paint spot etc, they can give you any colour you want chosen from swatches. They will charge around $20 odd bucks for a can and as you are going to need at least 6 cans, could be a bit expensive for some. Including me, I looked at the usual brands you find in Autobarn and fund that the K&H brand to be of good quality and was recommended by a few people after doing some google searching. They do make a wheel paint but it only comes in a chrome colour, champagne and black, which was crap but I ended up using one of there 300 degree engine enamels in the Grey. All of these ones cost around $15 and there is a multitude of colours to choose from.
2 cans of primer, 2 cans of paint, 2 cans of clear. This may differ for you depending on what kind of condition your wheels are in, if they are in a bad condition you may want to put a few more coats of primer. Also the more shinny you want your wheels the more coats of clear you have to put on. I think all up I spent around $70-$80 for everything so not bad for a totally new set of rims essentially.
Right so onto the steps of doing it.
STEP 1 - Cleaning
The wheels need to come off your car to do this project and it ended up taking me about 2 weeks to finish doing it off and on so if you don’t have another set of rims to use you might want to start the project really early in the morning on a Saturday and you should have it done by Sunday arvo. (I’m just slack)
Take the wheels off and give them an absolute smattering of degreaser (removal of the tyres is not required) if you rims are greasy the paint will simply not stick. Secondly give them a kick arse scrubbing with a sponge and even steal wool or something that will really give them a good clean, don’t use something that will make deep scratches like a wire brush though.
STEP 2 - Sandpapering
Your rims will have there own coat of clear coat on them, and you need to get that removed as your new paint needs to stick to something not so shiny/smooth so get out your sandpaper and give the whole rim inside and out a light sand papering. You don’t need to be too heavy handed here you will know when you are as you will see a dark colour where there used to be silver, this means you have sand papered off the clear coat and the bottom paint coat  don’t worry if you did this a little.
STEP 3 – Masking
Okay this is a pretty time consuming process so prepare to be bored. First of all make sure that you have given the rims a really good wipe down with a damp cloth to remove any of the sandpaper dust. Then get to work with small strips of tape in around the rim where it meets the tyre. Make sure you get the tap right down in between then stick it down to the tyre. Do this for the inside and outside of each rim. It probably took me about 10 minutes to do each side so times that by 8. Once that is done you need to stick down news paper to cover the tyre, I went a little crazy and totally encased the tyre which you probably don’t need to do but it made things easier to move them around/turn them over. Also don’t forget to tape up your tyre valves…
STEP 4 – Primer
Time to finally paint, this part is pretty self explanatory. I don’t have any proven mythical method for painting but the advice I would give is more is less, doing 4 light coats is 10x better than doing 2 heavy coats. If you get paint runs don’t wipe it off just leave it as it can be sanded down later. Doing the primer is a good practice for your real paint as you can’t afford to get runs in that. Also painting the rims when they are flat, not standing up makes it harder for the paint to run. Start with the can further away then move closer, don’t start close or you may end up with a puddle.
Once you have done your primer coats get the lightest sand paper you have and give the prime a real light sand, and I mean real light sand just to get rid of any lumps or runs of paint.
STEP 5 – Paint
Essentially this is the exact same step as the primer, take your time, leave at least and hour between coats. I found that with both the primer and paint I did about 3ish coats of each.
post-40810-1214966090_thumb.jpgpost-40810-1214966099_thumb.jpgpost-40810-1214966136_thumb.jpg
STEP 6 – Clear Coat
Again the same as above but with the clear coat you really want to make sure you are doing it lightly because its really very difficult to see how much is going on, so use your experience from doing the paint and primer get the can distance right and go for it. I ended up doing about 5 light coats of clear.
post-40810-1214966145_thumb.jpgpost-40810-1214966152_thumb.jpgpost-40810-1214966188_thumb.jpg
STEP 7 – Finishing off
All that’s left now is to let it dry really well for at least a few hours (preferably overnight) then remove all your masking and fit them back up to the car 
Jobs done
TIPS
• Spray cans will last longer on a shelf by clearing the nozzle of the can, hold it upside depress the button until there is just air spraying out. Now the nozzle isn’t blocked and will spray perfect every time.
• Spray where bugs and dust etc aren’t going to get on your work
• Spray painting is not the best stuff to breath in, have a door open somewhere or do it in a reasonably well ventilated area and take breaks from spraying every so often. Use a spray mask if you so feel the need.
*I don’t take any responsibility for your health or the quality of the job you do so don’t blame me if you make mistakes etc this is just a guide and should be used so, i am not a professional and don't claim to be*
https://www.sau.com.au/forums/topic/226407-wheel-painting-d-i-y-tutorial/
Yeah makes a big difference to the look. I really couldn't stand mine silver so i was feelin bad about takin off the GTR rims n puttin these back on but now they're grey i don't mind em at all :laugh:
Cheers
How good would the photo shoot be.... your white car with the dark rims, and my black one with the silver rims.... gawsh the POSSIBILITIES, GENTLEMEN!!! Mentlegen...
hahaha yeah would be alright ey! bit of distance to cover for a photoshoot though. If there was like a massive muster organised on some middle ground i'd be keen on going but would need to be a big event :stupid: Xmetal would get some good snaps for sure
Good read, I have already painted 3 of my stock 33 rims... Got one more to do tomorrow.
Have painted them black. Going for the White car/black wheels theme. :stupid:
Cant wait to see what it will look like on car
This should be moved to the DIY section. It's a good tute and it might get lost here!
Anyway, i heard a little rumor that you can put playing cards around the rim instead of tape. They slot in between the rim and rubber.
Haven't tried it, but sounds quick.
Top job mate :stupid:
Edited by R338OY
Top job mate :)
yeah not a bad idea that one! didn't even think of that... nice1
I think they topic has been added to the DIY section :) thanks nick
hahaha yeah would be alright ey! bit of distance to cover for a photoshoot though. If there was like a massive muster organised on some middle ground i'd be keen on going but would need to be a big event :) Xmetal would get some good snaps for sure
Just meet half way....In Newcastle! :)
Top job mate :P
I think they topic has been added to the DIY section :( thanks nick
Yep, already done - but it's only in the Stagea DIY section. I'll have to see if I have the authority (but I doubt it) to add it into the general DIY section.
Just meet half way....In Newcastle! ;)
Yeah, I'm up for that. Saves me going to either Queensland or Victoria. It'd be hard to choose otherwise, because I also have relo's in both states who I want to see...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
