Hi all , does anyone have pics of the turbine side of an RB26 type HKS GT-SS turbo - or the Garrett GT2560R 707160-9 which is suppoed to be exactly the same thing ?
I'm just trying to find out if their turbines are the usual base model Garrett GT25 BB turbine style - 11 bladed and the fronts of the blades lead forward - you'll know what I mean if you've seen them .
The Garrett maps of these turbos (CHRA no 446179-65) look pretty good BTW .
Cheers and thanks , Adrian .
https://www.sau.com.au/forums/topic/226432-gtr-gt-ss707160-9-turbo-pics/
I can get some for you tonight if you still need 'em. got a pair of HKS GT-SS at home. and another set on the 32 in the garage. :laugh: they are pretty good. spool up pretty hard. 15psi at 3700rpm.
Yes Beer Baron that would be much appreciated .
I've been reading up on small/medium sized Garrett GT25/28 based turbos because I need something smallish for my daily dinosaur Subaru Leonie RX Turbos engine .
I looked through the maps on the turbobygarrett site and it looks to me like the 707160-9 turbo is exactly the same as the HKS GT-SS GTR turbo - except possibly the waste gate actuator .
Could you possibly confirm for me that the GTR GT-SS turbos ID no's are 707160-9 and or CHRA no 446179-65 .
Also interestingly the compressor wheel OD is slightly different (59.4mm 56T) to many BB GT25/28 based turbos that usually have 60.1mm OD 60/62/63 trim wheels . It makes me wonder if it was a special cooked up by Garrett at HKS's request .
I'm also going to talk to Brett at GCG to see if its practical to fit the lighter/larger trim GT28 NS111 turbine to this cartridge and use the more common SR type GT28BB turbine housing . These housings are a little wider at the inlet than GTR ones and the mounting holes are plain rather than threaded for RB26 apps .
I dont suppose I could talk you into showing us a pic of the compressor wheel with the housing removed ?
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
