Two fold reason for this thread (its been awhile)
1.) Trying to generate some good discussion
2.) Will be replacing my pads soon
Whats pads do you guys use, why did you select that pad & how do they perform in different situations ie. traffic situations, highway, hills & track?
Pls keep on topic and try very hard not to whore this thread.
https://www.sau.com.au/forums/topic/226444-brake-pads/
  • Replies 87
I use EBC Greenstuff pads
They aren't the grabbiest of brakes in traffic, definetly much better than most cars. It's in the hills after a few hard brakes is where they start to come to life, The grab is so hard you tend to get over confident with entries lol.
Highly reccomended.
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987069
i dont mean to hi jack this thread pete, sorry,
but is it reccommended to change fluid?
as ill be getting a new brake pad and rotor set up very soon.
this is a great thread!
I use Bendix Ultimates. Really nice pads, havent had any complaints. They do shed a lot of brake dust but thankfully stock gtr rims are grey anyhow so no biggie :laugh: Might try the EBC greenstuff when I upgrade the rotors....
-D
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987108
Ferodo DS 2500 - have great bite and don't overheat easily. And they were $30 for all four corners at 95% brand new off an Ebay seller who brings in cars from Jp and has to change the pads when they get here. They are a bit brake dusty, but then so are any decent pads. Also take a couple of brake stops to warm up, but only a short time then u r good to go.
$30 and 1.5 hours of my labour = best deal ever imho.
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987126
I used Bendix pads called Street Road Track. I used them at Mallala and they were fantastic, my brake disks were what failed. I took them out when i changed my disks and put my old pads back in, so i dont really know what they are like on the street.
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987166
I use Bendix Ultimates. Really nice pads, havent had any complaints. They do shed a lot of brake dust but thankfully stock gtr rims are grey anyhow so no biggie :D Might try the EBC greenstuff when I upgrade the rotors....
-D
Same. I use Bendix Ultimates. But I wanna try Ferodo DS 2500 next time around.
BTW, yes you should flush out your system with new fluid for best results.
:sick:
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987423
ive used bendix street road track before and were great, good for hills and when i used to take the old s13 to the track but they cost abit too and worked alot better once they were warmed up.
ive got bendix ultimate in the r32 which were abit cheaper but worked really really well in traffic and didnt take any time to warm up to make them better etc but heaps of break dust and make a gay sound when they hit the wear marker.
ive also used project MU in the old s13, pretty awsome but abit to pricey for a day to day car. also worked alot better when your hammering the car around the track to warm them up.
Edited by Import S13
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987434
All good posts so far guys.....anyone had any experience with Hawke or QFM pads?
Mates using Hawke before in his S4 RX7 and he raves about them!! Used them at mallala the other weekend and he rekons they were great!
I've used bendix ultimates before, they were really good pads but so make dust!!
Heard nothing but good things about ebc green and red stuff pads as well!
Most of the jap brake pads are good, cost a few clams, but eh you get what you pay for!
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987507
This will be the 1st time I'm changing pads on the GTR since I bought it so I want to make sure its the right decision, hence the thread.
Unlike my Ford & Commodore dailys where pads are $50 for front & back and rotors are avail at your local fish shop for a couple of $, the GTR pads can cost up to 10 times that amount not to mention that I've got 2 piece floating & slotted rotors on the front that I don't want to chew up prematurely.
https://www.sau.com.au/forums/topic/226444-brake-pads/#findComment-3987572
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
