I am selling my r34gtt sedan 98 model is white auto stock wheels with ems stinger computer front mount cooler and 3.5inch turbo back exhaust sounds good and looks good in process of of working on a uras style front bar looking at $26000 ono any questions let me no.
im from sydney and will be taking pics and adding them soon reason for selling is buying house......
https://www.sau.com.au/forums/topic/226458-fs-r34gtt-sedan/
What? I can buy an R34 manual coupe from a dealer with less than 90,000k for under $21,000.
Why would anyone pay $26,000 for a WHITE - AUTO - SEDAN?
https://www.sau.com.au/forums/topic/226458-fs-r34gtt-sedan/#findComment-4030817
Why does it have non turbo headlights? Front ender?
Sorry dont no why is has these lights didnt know they were non turbo head lights and front end is turbo front end just be cut for more flow onto intercooler... working uras style front bar atm to fit on this car looks good once ready.... Is there anymore info you would like about this car.
https://www.sau.com.au/forums/topic/226458-fs-r34gtt-sedan/#findComment-4031312
