Yeah man been through a heap on my 33, it's even got to the point of them cutting out when i hit bumps, but cant find any issues with the wires or connections!!! i'm stumped, last time i drove it i had to use high beam the whole night cause low beam didn't work at all on either side!!!
oly thing i can think of is the clips that hold the globe in may not be connecting 100% of the time and shorting out the globes!!
just a guess though!
u gotta make sure u install them really really carefully i mean .. really really really carefully .. i used to connect them to the wire before i installed them and it was a pain to get in without touching the globes to the sides which risks putting dirt and oil onto it ... i went through 2 sets like this ... best way to install is remove the old ones ... don't connect yet .. install the new ones really carefully and put it in place ... put the clip on ... and then connect the wire to it after its been secured ... my last set has yet to die installing it like this ... so i guess i think that u guys aren't installing them good and getting them dirty .. :)
hippy, i installed all of my sets like this! i know what your saying though, seems a common issue!! with mine i can get them to work again by tapping on the front of the lights!! so its not caused by being dirty!!!
oh, so its not dying? well thats good :) .. check the ground connection is there .. i mean i think the circle plate which the globe sits on should be ground i think .. u got h1's right? well check if thats connected properly ... it sounds like an electrical thing and theres a open circuit somewhere ... fiddle around abit u should find where its not connecting ...
Yeah had a good look, actually took the headlights out (respray car) and can see any issues, but it does it to both sides but not really at the same time!! might have to send this one to the auto electricians!!! real pain in the A**E
Check the voltage on your battery with the engine running. Rev the engine a bit, the voltage shouldn't go any higher than 14.5 or so. Should probably be under 14 actually (not sure). If it's too high then you have a faulty voltage regulator, should be repairable by an auto electrician for around $100. If you don't fix it you will blow bulbs all over the place, and also run the risk of blowing up more expensive electronic gear.
If the voltage is fine, then I dunno :)
not sure about them, they are the small $1 ones aren't they, bit hard to replace!!!
how hard is your suspension? thats what started my issues!!!
i'm thinking of setting up an extra eathing point for the light clusters to try and resolve my issue!! see how that goes!
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
