this is whats left from my current project car
pics can be put up once there's interest
brand new tomei exhaust manifolds $1100
R33 GTR S1 headlights in perfect condition $350 each or $650 the pair
R33 GTR genuine front floor mats $85 the pair
R33 GTR factory Radiator was only in the car for 1 month so bascially its brand new $350
R33 GTR Front bar lip in average condition as it was previously repaired and needs repairing $250
R33 GTR Drivers side side skirt 2 piece $150
R33 GTR stock injectors $450 the set
R33 GTR Stock fuel rail $85
R33 GTR Trust front pipe $220
R33 GTR centre tripple gauges $100
R33 GTR factory fuel pump $110
R33 GTR Engine wiring loom $450
R33 GTR standard cams and cam gears
TEIN coilovers (left front coilover needs a rebuild) $650
os giken tripple plate clutch $1250
i have heaps more left over so if you need anything just ask and i might have it!
cheers
Steve
Edited by Nisswreck
can i get pics and is this just the clutch or the kit. what condition is it in
cheers mitch
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
