Hi There,
You may remember I had an issue with my R33 after I installed my exhaust..
The mods were:
Boost (10 psi) via bleed valve
Exhaust (3" from turbo & hi flow cat)
Air filter
FMIC (small - Medium size)
Oil/Air seperator
After I installed my exhaust I noticed a very bad flat spot (from 5000 rpm onwards)..
Had it dynoed and was not happy at all...
Did some research and worked out my AFM was faulty... Swapped it over with a mates and WOW..............
Check my dyno result (both have the same mods and same boost):
Cheers
Rob
Ps. Sorry about the small photo
https://www.sau.com.au/forums/topic/22651-fixed-my-flat-spot-dyno-result/
I was having that exact same 5000rpm+ flatspot. it was pretty bad.
yesterday i swapped my afm for a mates to try. Bingo! fixed.
feels like a new car... pulls harder than a schoolboy at girls camp.
I'm pretty sure its just broken solder tracks in the old afm giving weird signals with strong airflow
good on ya robo :)
Sorry for the late reply..
Yeah my old AFM was always a little faulty... At one stage when you just touched it, the car would idle like a yo-yo (up down, up down)..
Yeah tried cleaning my old AFM with electrical Contact cleaner but did not do much..
On warm days the car felt alright (at low boost) and then as the nights got colder it would accelerate really well until about 4500 rpm then just dies...(well just felt slow) really really annoyinng..
I'll tell you when I swapped the AFM, I could even feel the difference in 1st gear... Happy days.
Regards
Rob
Ps. Lets hope this fixes everyone's flat spots. haha
Usually when I first start mine in the morning it feels a little dead (like a flat spot) unless I give it a decent amount of acceleration.
Funny thing is when it is feeling dead boost also comes up quite quickly but doesn't appear to make the car go at all then I press the accelerator just that little bit more and it starts accelerating decently with a ever so slight hessitation. During this in first and second I can see a bit of smoke swirling around the arse end of the car in the revision mirror it looks like a real dark grey colour I can also almost see the black. Fuel?
This morning I didn't want that fuel cloud behind the car as a copper was right up my clacker as soon as I pulled out the drive way.
So i took off real slow not hitting boost in first or second and the car felt really dead..
Cruising on 60km's it requires more than normal acceleration when cold for some reason but this time maybe because I didn't blow the crap out by hitting a little bit of boost and making the cloud it started to miss and caugh.
I had to accelerate to just past 1/4 to where it started to take off and made the cloud a little.
It was then fine but still with a small flat spot or dead spot that can actually make the car make boost when cruising.
:) He didn't fix mine
Joel, the grey/brown/black cloud of smoke is definitely fuel, nothing to worry about at all. But flat spots under mild acceleration or when cold sounds like blocked injectors to me. Try putting some injector cleaner in with your next tank and see if that makes a difference. If not, then maybe try getting them ultrasonically cleaned.
Robo quoted:
Regards
Rob
Robo my rb20det is a dead replica of what you prescribed. I might go down to my import mate and see if i can swap afm's for a couple of days.
Thanks
Robo, looking at your dyno run with the faulty AFM, you must have been feeling a massive flat-spot which was very much not normal - good to see you fixed it!
I think the flat spot most people are talking about above is the levelling out of the power line towards the end as shown on your latest (good) dyno run.
I feel a small "flat spot" also around the 4500-5000rpm area, but I think all r33's cop this. If I compare my dyno graph to yours, it is basically the exact same shape as your new dyno run (the better one).
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
