  • Replies 68
Sly33 have you tried pushing anymore than 16.5psi? I thought these turbos would take 18-20psi on an RB25? That said I will be happy with 280rwkw if I can get it:)
yes, in my application it would not hold anymore than that boost. which gets me to thinking that its pretty close to its potential. 280rwkw works out somewhere roughly round 450+/- hp at the fly, seeing as the turbo is rated only at 420ps, that sounds about right.
i can squeeze more boost in the midrange, but as it revs out the boost drops back to 16.5. I havent gone to lengths such as wiring shut the wastegate or anything like that, as ive heard some have done to get to the 300rwkw mark with this turbo. thats gotta be pushing it, and ive been happy with the 280rwkw. The stock honed ex manifold is purely just for experimentation rather than chasing more power!
Ill leave the car as it is until i put a 26 in it, and then sell off the whole running forged rb25/2835pro setup, including literally everything, injectors, tuned power FC etc.. anyone who wants this setup down the track keep mine in mind :woot:
Seem like a real solid turbo for the RB25DET.
Question. You guys running on MT or AT ? Cos I wonder how will the AT box that this turbo.
MT all the way baby :(
weird how it wouldn't hold boost... mine is pretty happy @ 20 for a most of the range... what bc are you using?
remember that running more boost isnt necessarily good, especially if one setup is making more power with less boost.
sydneykid would tell you mine is more efficient hehe :D
that said though i think my above post relating to the turbo simply reaching its airflow potential sounds about right. I had exactly the same deal when trying to push the 2530 (using an e-boost).
now running a blitz spec-r ebc.
Edited by SLY33
had a close look at your car while i was there man.. very nice :)
rob was telling me about your car, sounds really good congratz on that!!
Now i needa get my car going agen :) 3076R .82 and try reach the 300kw mark agen :D
thanx phil!... that setup should see you @ 300 fairly easily i'd imagine...
sly33: true that i'm running a fair whak of boost to get the 265...
but comparing dyno's (to your non built 266 one) i'm getting 170rwkw by the time your's is on 130... who's more efficient now huh :P
Hey Phil car is back on the road mate :)
The run-in tune has been tweaked, but a full tune is still required once i have clocked 1000km.
VERY happy with the result!
rb30det + GT3076R = 304rwkw@16psi with instant response :D
rb30det + GT3076R = 304rwkw@16psi with instant response :)
Thats really impressive already - you will be going for 20psi or so? What is your setup, internally gated or a high mount w/ external? Stock or aftermarket plenum?
Thanks.
Full tune will consist of 20psi, setting the adjustable inlet (modified the std gear and maintained the VVT) and exhaust gears, boost controller (as it is currently working just off the actuator), rev limiter set to 8000rpm, more ignition timing and better tune.
All items stated above are subject to gains gained. ie: if no valuable power/torque is gained from increasing boost to 20psi, i will leave it at a reasonable boost setting. Same goes with the gears, timing, and rev limit.
PM sent.
Cubes: the curve feels alot better than it looks too :D
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
