For Sale/swap
Make: mazda
Model:89-90 familia
Milage:
Transmission: manual
Colour: black
Complied? yes
RWC supplied?
Currently registered? yes
Price: 7000
Contact: 0420502246
Comments / Modifications: it was rebuit 8 months ago and the motor sounds very tight Has a bb t28 turbo with 3" dump pipe. front mount, full exhaust, boost controller set at 10psi, clutch is good and grabs quickly, car is black, interior is clean except for passenger door trim is spongy under the trim, has rare 3 factory guages in center console, cd player with front and rear speakers. has rego till november. want to sell or swap as i just came out of a rb20 r31 and missing the rear wheel drive.
Images:
Make: mazda
Model:89-90 familia
Milage:
Colour: black
Complied? yes
RWC supplied?
Price: 7000
Contact: 0420502246
pics up soon
Images:
 Share
    • It depends on what the guy who bought its Ratio is. Mine is a 4.36 Jus Jap told me anything above a 3:9 has equal length shafts which the Nismo center's shafts were not.
    • If those shafts in the last 2 photos are the ones that came with the diff, you have no hope of fitting the other ones because they are completely different
    • I have recently fitted a Nismo GT Pro Center second Hand buy still in the box i got stubs with it but they are 5 bolt and I need 6 (3x2) I was told by Just Jap that for a 4:36 ratio the stub axles are equal length sku 38220-0V161. They didn't have any in stock but I picked up the ones pictured. The one with 5 bolt are the ones that came with the LSD. The right side went in no issues but the right....I have happened the fk out of it put it in a press and it still sticks out about 5mm too far. It was sticking out about 25mm but after bashing it like Chris Brown did to Rhianna I managed to get it a bit further in but seems stuck again now. Any ideas? Should I just leave it 5mm out and send it?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
