ooh like some of those last ones
out of interest you have a copy of the originals of that blue 300zx?
(like before you played with the colours)
Thanks :O
Um i'll have a look through my photos for ya for an original of the 300ZX - but if i havent, im possibly organising another photoshoot with him in the next week or so so i can show you some original photos then :)
  • Replies 52
Haha no worries - thanks for the tips though. Criticism is good - helps you get somewhere :cool:
You've got hotspots everywhere, you can't see the front bar and the sky is blown out.
To fix this you'll need a polarising filter and shoot an a time later in the day when the glare is gone.
Other things you can use are 1/2 ND filters.
I can quite clearly see the front bar, all that there is, is a couple of bright flares as a result of the sun reflection.
Also i looked back through my originals and the sky IS white. SO obviously no matter what i did changing the levels or curves, the sky would have been white nonetheless.
Look. I've only started out in photography and i have no filters - heck the camera i use isn't even my own. These photos are just for an assignment - nothing to professional thats for sure.
But thanks anyway?
Some photo's taken with my 400d at home the gold coast and at mt tamborine. contructive critisism taken on board for future.
I love the fire twirler photo, and also the polar bear. And jeez that zombie looking thing is ugly! Haha.
SHouldnt we start an August thread now? :P
some good shots - my advice would be to watch out for taking photo's that aren't quite level - kinda hard sometimes - i do it myself all the time too
(ie talking about shots where you can see horizon for example)
ps started august photo thread (ps anyone can start it - so next time 1st person to post in the next month should start it ;))
large norks
lol
I’m at uni, so i had to scroll down very quick so i didn’t look like a weirdo
Loving these threads guys. Keep up the good pics. Looking and getting a decent camera soon, Can’t wait to start taking some snaps.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
