Also bear in mind that if fuel hits $2 a litre, you'll have 3 tonnes of scrap metal sitting in your garage :)
Ditto
...unless you then do a mobile home conversion in the back; and an Impala kitchen in the front. :P
is there a particular reason why in other states they prohibit the use and registeration of LHD cars?
i personally think it would be awesome. its better to see people driving in a LHD porsche 911. its just more original.
There is a guy here at work that has a LHD 'stang.
the old school ones. 57 I think?
Anyway to get in you need a proxy card. he has his on a stick to poke through the other window, but still needs to put the window down cause no power windows.
It's a good laugh - especially in the rain.
  • 3 months later...
hmmmmmm
i think that if u contacted USA workshops who can convert ur car before shipping it to australia
i think it would be cheaper
try looking for conversion work shops in the USA and ask them if they can do it for u
All conversions have to be done in Australia, they will not permit a vehicle to be converted to RHD in the USA and then shipped. Already been down that road. Besides as R33_Dude said there are a lot of custom parts that they have no reason for having in the USA so you have to pay them to create all the mirrored parts like the dash so that wouldn't cut costs, it would probably add to them.
Also in the cost calculations there has not been mention of Duty which is not payable on vehicles made prior to 1989 but is applied to all vehicles made after 1989.
Another factor to add in, depending on the circumstances is Luxury Car Tax if you were buying a newer model and it pushed the price over A$55k.
The good ol' Aussie Government sure do like getting a slice of the pie... a really big slice!
This may be a stupid suggestion but if you had to get it converted to RHD and have all the dash and stuff changed aswell for $40k couldn't you just get a complete custom dash done with the conversion for roughly the same price?
And WTF-33R you can register and drive LHD vehicles in WA (I looked at a Camaro and a Transam before getting my R34) but they have to have been manufactured before I believe 1990 (I could be wrong), after that it must be RHD.
I doubt it as the reason they require the conversion, in theory, is to make the vehicle safe to be used as a daily driver and if you then went and made a custom dash you would be modifying the vehicle in a way that was not tested and therefore could be unsafe. You would have to compliance the modified dash one would think.
The law in all states is that if the vehicle is older than 30 years then it can be left LHD. The reason for the 30 year rules is that they figure a 30 year old car will not be used as a daily driver so therefore the LHD will have no real impact on day-to-day motoring. The exception to the 30 year rule is in NT and WA where it is 15 years old. In SA if the vehicle is not completely factory stock they require you to convert it to RHD even if it is over 30 years old.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
