These books contain almost every imaginable option for your car!
Everything from vehicle history, technical data, engine, interior, suspension and body components to the wildest of modifications are on each page and includes pictures of specially built vehicles and parts that most people outside of Japan would not even imagine were available!
HyperRev is regarded as the definitive owners bible for tuning and customization.
Each issue is precisely focused to a particular make of vehicle and includes in depth reports, features and product listings spanning the entire spectrum of OEM and aftermarket performance tuning and styling.
Most HyperRev books are between 200 and 300 pages. For popular cars there are often multiple volumes of HyperRev books that are released.
Enthusiasts worldwide have found HyperRev books to be an invaluable resource for learning about new performance parts and planning the modification of their vehicles.
Please note: Although HyperRev is produced only in Japanese, most brands and product specifications can be read and understood in English. Needless to say, the full color pictures speak for themselves.
Features included in this Magazine are:
Shop and Manufacturer Demo Vehicles
Engine & Suspension Tuning
Circuit Spec Machine Reflections
Bodykit and Dress Up Parts Guide
Gauge, Meter, Interior Accessories Guide
Engine Tuning Parts Guide
Drivetrain Parts Guide
Suspension and Safety Parts Guide
Wheel Fitment Guide
Plus more...
update price $55 delivered in (stock items only) -
please note if issues have to be ordered in eg latest editions freight charges are added
here is some sample pages from SILVIA edition 6 (no.102):
We have hundreds of other titles ON THE SHELF (SUBARU, MITSUBISHI, MAZDA, TOYOTA and so on)
  • 4 months later...
due to aussie dollar slump the 3 for $100 isnt available atthis time we can do it for $120 but for on shelf items.
FC is available but its combined with FD in same book
Hey Guys,
Do you have anything with detailed info on 1992 R32 N1's? I'm trying to gather as much info as possible, especially stock specs of car.
cheers
Bobby
Hey Guys,
cheers
Bobby
Hi Bobby
if there is any info on the N1 it will be incorporated in the GTR books as parts are the same these are aftermarket books they may niot have much info on stock form vehicles sorry
Hi There,
I have a BNR34 V-Spec, can u tell me wats the diff between:
HR 100, 109, 15, 58, 90
and which 1 would be better to get (i only want stuff that is relevant to my spec).
thanks
hi guys as with the other question regarding the N1 R32 the hyperrevs focus on after market components and an example for an R34 GTR almost everything will suit the entire 34 GTR range whether it be N1 through to NUR Spec as the parts are all the same ie wheels, elec, bodykits so on
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
    • Alcantara all the things!
    • These arn't them, but these are the pieces.  I dont think hydrodipping would work. Also, the plastic is very old and brittle, the trims are out of the car atm getting some mounting holes jb welded.
    • What about hydrodipping? I was looking at it but if the piece is complicated the end result might not be as good, I've seen it recently where if you have a checkered pattern for example and dip it, the area where the plastic bends, those checkered boxes look stretch. Doesn't look terrible but not the best result either.  Every rattlecan job I've seen has turned out crap (at least on the skylines, they are always peeling and bubbling) but I haven't seen anyone get a proper spray gun and compressor and go at it. In theory they should last a lot longer. Vinyl wrap is another option (also difficult if there are a lot of complicated sections)
