Hi, I'm interested in getting a V35 and I have found a perfect one with Nismo body kit, 6 speed as standard. The problem with it is there is no stereobut there's speakers on the door & Brembo's. He guy told me it's a track spec model. Is it true? I can't find anything related to it. He also said the suspension is stiffer too. Anyone can share a light? spec?
Edited by FlyingEL
https://www.sau.com.au/forums/topic/226556-v-model/
no stereo??
no V35 came without a stereo!
there was a "track" model which had a LSD, 18" wheels, brembo brakes, momo steering wheel
and i think some of the 2005 onwards versions had stiffer suspension on these models
but if it was an earlier model (2003/2004) then i think the suspension was the same across all coupe's
i would be wary if there is no stereo, why on earth would someone remove it unless it was broken or damaged?!
what else has then been removed?
https://www.sau.com.au/forums/topic/226556-v-model/#findComment-3988996
You'll see a lot of 03/04 manuals referred to as "track spec".
This is because in Aus the 350Z with brembo's was called "track" model and so alot of people use this to describe the cars with Brembo's.
I have never seen a "track" spec V35 Coupe from japan. Things mentioned above came as standard or optioned on certain models, and the only name the coupe has ever had is 350GT Coupe. The only exception to this is the Anniversary edition. Which was 350GT Anniversary Edition.
https://www.sau.com.au/forums/topic/226556-v-model/#findComment-3989145
IMHO - Stock suspension is firm enough, any stiffer than that is not required unless you want to take it to the track... and pull out all the trims like Waz did and put some felt in to reduce squeaking... the stiffer the sus, the more squeaks you'll hear!
https://www.sau.com.au/forums/topic/226556-v-model/#findComment-3992598
looks good actually...if th stereo was professionally removed and you've already got the double din conversion then all thats needed is to buy a double din DVD unit stick it in and u've probably ended up with a better stereo from factory complete with DVD etc...as Chris said, an easier fix than if you had all the factory and NAV stuff to pull out.
+ ur getting the kit + brembos + 6spd. Doesn't matter if its non premium, you've already got most of the good bits on it minus the leather seats + bose
https://www.sau.com.au/forums/topic/226556-v-model/#findComment-3993369
  • 1 month later...
I think your on the ball there
This might seem a bit strange to ask, especially since all the stuff I have read just today but can someone please confirm that the Stereo is below and in front of the Screen and this Screen drives out of the hole at the top of the Centre console. The Screen is usually hidden from view.
Is this on all models or just some... does the Screen pop up and do all Sedans and Coupes have it, or just the Premiums, or the one's with TV/DVD option?
If it is a TV/DVD option I presume that this also means that you get a Trip computer as well as a TV, that only works in The land of the long white cloud.
Isn't a Double Din head unit standard across the range and the Bose (Double Din too) an option on all models?
How do you know if the wiring and (Japanese) hardware for TV is fitted to your car, where do you look?
Getting kinda excited with all this research and all of you guys appear to have a great car, with so many things to think about before I go looking and driving. I hope I like them to drive...
Cheers all
https://www.sau.com.au/forums/topic/226556-v-model/#findComment-4077575
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
