Hi ppl,
I have been trying to install a stereo for the last two days (damn long condsidering i've installed about 6 units in other cars). The car is an R33 S1 2door. I have fixed my previous problems but have now run into some new ones which I need help with badly!
Problems are:
I have nowhere to mount the stereo! The original brackets are missing and I'm left with a nice double DIN sized hole. I need to get some sort of frame to mount the decks cradle to, and will also need a single DIN pocket. Question is, does anyone know of a dash frame/chassis from another car that will fit to the skyline? I need the actual metal bracket that fits two DIN slots, one for the deck and the other for a plastic pocket.
Other problem is the aerial connection. It looks like it has a weird plug shape with 2 prongs?! Anyone know of an adapter to mate the jap aerial to an aussie spec aerial?
Thanks in advance for any help.
cheers.
https://www.sau.com.au/forums/topic/22656-stereo-installneed-help-badly/
go to ur local autobarn or car audio shop .. they will have the conversion adaptors for about 30 bucks ... so then u can install american or aussie stereos ... go to a nissan wrecker ... i think u maybe able to get brackets for pulsers and 300's to fit .. i'm not sure ... just find one that wrecks skylines :)
i had the same problem u will have to find other car brackets of make them ur self from cuts of metal which i did its a bitch to get the deck to be straight. You can get a din from nissan but they do cost $40 but the s15 one fits also which might be cheaper.
Do u have holes on the side of ya dash that u can screw onto if so ur lucky cause mine didnt even have that goodluck!
damn it!!!!! I bought the brackets from another wrecker (closer), but they aren't enough... the brackets I bought are kind of L shaped and fit deeper inside the dash, towards the back. There is no way I can fit a deck to them without it being about 3 inches deep from the facia. I spoke to a mate who recently put a stereo into an r33 and he said I am missing more brackets.
Is anyone on the forum wrecking an r33 with these brackets?? I would love to basically buy the whole bracket/cradle setup that goes with the deck right back to the internal dash rails.
i finally just finished getting that mother(*@#$ in!!!
talk about an absolute **** of a job.
Now the problem is that the dash doesn't clip back in properly (the facia around the stereo) and there is a slight gap under the DIN pocket.
Oh... and another problem.. Now my passenger side headlight doesn't want to work. I took the bulb out (what a bitch that was) and it isn't blown at all ?? It looks like a bad connection or old wiring. Anyone else have this problem? And can anyone else tell me how in the hell I am going to be able to get the bulb back in the headlight with the clip?
Firebladejr,
Go genuine with the brackets - you'll pay for them, but at least they'll be the right ones.
As for the funky jap aerial adaptor, I went to our old mate Dicky Smith and bought a single prong connector. Costs all of about a dollar. You can cut the old two prong connector off, and simple wire the new one on by twisting both cores together and soldering (obviously the ground sheath is the same).
I did this to mine, and there was no probs - surprised myself.
didnt u get mounting brackets with your head unit?
they fit in there snug, but i couldnt get the console back on.. because it stuck out too far.. it was a simple case of drilling new holes in the existing mounting frames.. to get the unit to sit deeper in..
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
