Thats just the change interval sticker, do you have service records? if not assume it has not been changed
Genuine Nissan belts come with a similiar sticker that has the as space for the kms to be written on.
This is then stuck near by so easy to determine belt has been changed.
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3989351
Yes it should mean that belt was changed, but, the only way to know for sure is to take the cover and have a look yourself. I have recently done a timing belt change and mine was about 40,000k's old when the 100k service was due, (damn those skyline odometers are spot on lol), Undo the fan and remove then you will have some space to get cover off(may need to take belts off also) mark all things that your not sure of with alignment lines to help put it back as you found it ie cam-timing sensor. You can get engine manuals from jpnz for around $150 and I would highly recommend one of those as it will help you save a shitload of cash not having to fork out for a mechanic :D
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3989357
thanks guys
ive changed a belt before just not sure if that sticker means "100,000 service due soon" or "100,000 service completed"
so guess when the engine is out the cut ill inspect the belt
do worn belts have cracks in them or are they just saggy?
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3989364
  gfunkk said:
thanks guys
Belts can have many causes they may lead to failure. The way i look at it, at the end of the day a timing belt is seriously one of the cheapest parts you can buy for any car. If in doubt just change it...its going to be a hell of a lot more expensive if it lets go..
Cheers
Cam
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3989907
  Trav33 said:
I understood that the sticker was put on at the time-of-manufacture, and was a reminder that the belt needs to be changed at 100k.
Mine doesnt have it, and it would be the first manufacture release I have seen with it, however most service centres here would write next change at 200k or place the sticker to say 100k done like that is. Pull the cover off and have a look, update post and put me outa my misery
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3990223
  gfunkk said:
thanks guys
If you start seeing cracks it usually means it is due for a change. However in saying this - the timing belt is a rubber part and it will deteriorate, therefore age can sometimes be of more concern as opposed to Ks. So if your car is older than 10 years old and unsure of the history i highly recommend replacing the timing belt for piece of mind. I also recommend this for hoses too.
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3990327
Ignore what Todd and some others have said, the sticker is informing you WHEN it needs to be changed, NOT that it has been changed.
With regards to Skylines and other imports, you can not determine when or if the belt has been changed, and sometimes even taking the timing belt cover off and checking wont give you an indication of age.
Play it safe, if you dont think it's been changed, GET it changed, the belt it's self (for a Nissan CA anyway) is something like $27.
For a $3k+ rebuild, dont risk the timing belt.
Also, some places have different ways of notifying ysers of the change, either by removing the sticker, or placing a new sticker on informing of the change, my CA powered 180sx, the wanker that did the change simply removed the sticker and scratched a 1 in the timing belt cover to say it was changed once.
B.
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-3994380
  • 9 months later...
sorry to hijack the thread pplz but...i was told to replace the water pump along with the timing belt. wud that be rite? i'm looking to change the belt myself for the first time.. currently downloading the workshop manual. if any1 needs it feel free to send me a pm :banana:
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568103
Your timing belt was changed at 63,155 km's.
The Chinese / Japanese character next to the 12 means (Year) and the Chinese / Japanese character next to the 4 mean (Month)
So the timing belt was changed on the 12th Year of the 4th Month...
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568120
So when was it changed? The RB25DET is from a R33 skyline. So was it changed 12 years after 1996 or in 2002 or what?
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568211
  zerotohundred said:
sorry to hijack the thread pplz but...i was told to replace the water pump along with the timing belt. wud that be rite? i'm looking to change the belt myself for the first time.. currently downloading the workshop manual. if any1 needs it feel free to send me a pm :P
yes people generally change the water pump while doing the belt
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568227
I got my parents to translate it for me as they are Chinese.
Ok the Top (last bit) of the sentence translates to "Change of Timing Belt at"... 100,000km"
Not sure what the middle sentence translates too as it is in Katakana (My parents can only read Kanji)
The last sentence translates to "Timing Belt was changed at" (in you case) 63,155km's on the 12th Year and 4th Month.
OK... Most timing belts in Japan would have been changed just before the 80,000 km's mark.
More importantly is the year it was changed. (12th Year of the 4th Month)
The Japanese year system is based on the emperor's reign.
The Showa Period ended in 1988, so a 1989 build car is Heisei 1.
If I have decoded this right,
This year is 21 (1988 + 21 years = 2009)
Your sticker says (12th Year) 1988 + 12 years = 2000
So it seems your Timing belt was changed in the year of 2000 in April.
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568567
That makes sense...
https://www.sau.com.au/forums/topic/226569-timing-belt/#findComment-4568606
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
