  • Replies 96
i have an update - i spoke to andrew from crd & he states the following:
- when u start the car the knock level can be distrupted hence the hand controller should always be reset after starting (u are right paul)
- if i hit rev limiter on the 1/4 mile this will also register a high knock level at times from noise etc when the exhaust pops & carries on
no need for a check with my tune - ready to go this wed night :D
yeah my clutch let me down but as paul explained "drag radials will always uncover the weakest point of the driveline"
from here i had a 'relatively lengthy' discussion with jim berry (LOL personal joke) & paul aka TWOOGLE!
my options are to either go with jims 'full monty' big single OR rebuild my existing twin plate clutch...both paul & i agree that i should stick with my twin plate which is the path i have decided to take.
im off to phuket as of tomorrow, as soon as i get back im onto my clutch as im keen to get out there ASAP & get kicked off the track :D
brett - as long your clutch is healthy (as i think mine had its fair share) your twin plate is perfect for your application!
good luck with your run & make sure u post your results on this thread, i'll be checking at an internet cafe :D
i did a short 2nd gear burnout then launched it @ 8000rpm - as soon as i got into top rpm of 1st gear i could hear it slip...2nd & 3rd gear did the same thing.
this is why i did an 11.7 but my 60' was 1.57 - there is still room for more improvement on my 60'
yep - i had a 10 in the bag
Id say he has a tune issue, or if he is using a fuel cut as a rev limit then it is self explanitory, should always cut ignition, not fuel.
Never had that problem ever, both of my gtr's never go over mid 20's even on 40c days running to redline many many times.
might be more of an issue that a piece of rubber was getting sucked up into his 044 intank pump and blocking it causing a fuel flow issue....nasty lean outs...ouch!
And you know you're trying your hardest when you lunch everything and try to take out one or all of the following:
- Your feet
- The car
- The track
- The timing system
- The officials
- The fence
- The crowd
Isn't that right, Ben?
:P
Mate their is no point calling up a tilt tray just because you have a slipping clutch or you snapped an axle - smash the damn clutch (and everything else) and THEN you have a reason to call a tilt tray.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
