  • Replies 96
It will be your first 330' that is letting you down, compare that time with your mates XR6T.
good point - i'll find out & post it up
1 of my mates has got 2 MT's for his r33gtst - he offered that i can borrow these if i like (nice guy).
will it be an issue running MT's on the back with my 18's (or street 16's) on the front? im not sure if the difference in rolling diameter will damage the driveline in anyway.
the MT's are 255 profile on 16" rims.
Edited by Marko R1
yes i have ohlins struts with i think standard shocks - i was talking to a mate who has done a lot of runs on the 1/4...he analysed my numbers came to this conclusion:
1. his xr6 turbo did a 10.89 @ 124mph (his half track time @ 1000' was 6.9sec)
2. my gtr did a 11.4 @ 127mph (my half track time @ 1000' was 7.45sec)
so i have the mph as above which means my hp will take me to a 10sec pass - however my 1/2 track time is .55 sec slower.
this is where i need to make my gains, getting to half track quicker!
even if i added more power (say 30kw) it would only give me a higher mph but not necessarily give me a much better ET time, might give a 1/10 or so (i compared a pass where i did an 11.8 v's 11.3 & there was only .05 of a sec in it from 1000' to finish line, not even 1/10 of a sec)
from this my mate thinks i would get better gains putting in a set of matching shocks/springs (i.e. factory suspension or soft teins) as my car does not squat at all when i launch, the front would be lucky to lift 1-2 inches & it tramps when it gains traction at the top of 1st gear!
so i think i'll get some stock gtr struts & try that - if i can do a 1.7sec 60' with 18's i can also fit the 16's with street tyres which should give me my 1.6sec 60'.
if all goes right & i pick up my 1/2 track speed by a conservative .3sec (i.e. 7.45sec to 7.15sec) & another 1/10sec from my 60' (i.e. 1.7 to 1.6) i will achieve my 10sec 1/4mile!
In a 4WD try and keep the car reasonably level...our car used to madly squat and lift the front skyward. We were using stock springs and shocks with the fronts revalved 90/10 and the rears 40/60...good for a RWD car but not suited to 4WD. We put circuit HKS coilovers back in the car and set them to full soft all round with plenty of ride height and bingo! 60's went from 1.7-1.6 to 1.5-1.4...worked well. Just something to consider.
So the MT's are 255/50/16. What are the 18's?
Need to work out the tyre height.
im not sure of the exact tyre height so i'll check this...so if they are almost the same tyre height i can run the MT's on the rear & 18's on the front?
this would be better than 18's all round right?
well i have 3 wheel combinations for the front which im hoping 1 set will closely match the MT's @ 255x55x16.
this is what i can run on the front:
- my brothers 16" factory rims with factroy tyres (nfi what the aspect ratio is)
- my 255x35x18
- my brothers 275x45x17
its probably best that i just put a tape measure on these wheels & see whats the closest fit for the MT's
my mates xr6 with the 10.89 did a 4.47 330' whereas mine did a 4.70 330'.
his 60' was 1.53 & mine was 1.70
So you were 0.17sec behind after the first 60' which is about 0.4 for a 1/4 so your 11.3sec minus 0.4 gives you a 10.9sec and your mate has done a 10.89sec
Get a set of R32 GTR standard rims with 255/50/16 MT Drag Radials and practice your launching.
i just need to know if i can run MT's on the rear with standard wheels on the front without hurting the 4wd system - has anyone done this with a gtr or is there any pics of quick gtr's with this setup?
otherwise i'll stick with the 16's all round with worn rubber
Edited by Marko R1
If the rolling diameter is the same its obviously o.k, other wise it is not advised.
you seriously would not consider doing it if someone on here told you it would be o.k,
they accept no liability for the damage they might occur and you are left with a repair bill.
also defeats the purpose of having an AWD car. just run it in RWD only. it is sixting slower than a RWD anyway,
otherwise run MTs all round, you will be stoked with the difference.
i just measured the height of the MT's for the rear - they are 650mm.
my 18's on the front are 620mm so i highly doubt that my brothers 16's or 17's are going to match.
looks like i'll be running it in rwd on MT's - or should i go with the factory 16's all round on worn rubber in 4wd mode (they are almost slick).
I know i'm like the 10th person to say this. but why won't you just run the MTs all round? you seem to really be set on running MTs on the rear only, or worn 16s all round and just waiting for someone to say 'yeah, that's a good idea'. but it's not a good idea! the guys with the drag interest are saying 16inch MTs all round is the go and I would take their advice.
you're right - i think a no response means its not a good idea.
i'll be running the car next wed so i'll post my results :woot:
where is the best place to get MT's or nittos? someone mentioned rocketindustries are cheapest...
You will learn quickly with these cars that you can do things half arsed and get half a result or you can spend the cash and do it properly and not have to worry about it again.
In the end its cheaper to just pay the cash upfront and do it properly instead of constantly chasing you arse. Take a look at the www.HPI.com.au drag records to see what combo's are being used.
Im lending him my rims and tyres...he'll only need them for 1 pass...but has to come to Newy to pick them up and drop them back off.
paul - like i said YOU ARE A CHAMPION - LEGEND! :D
yes it will be 1 run i'd say as once u crack a 10 there are other requirements such as rollcage etc...what else do they ask for?
mate you have always been one of the good guys on here...glad to help out. A case of Coopers red will acompany pick up and delivery. A small price to pay i think.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
