  • Replies 96
i'll be running the car next wed so i'll post my results :P
Still running tonight? I'll look out for you :down:
I've always had 60ft problems in my GTR, 11.7 @ 122... I'm looking forward to seeing what improvements you make :laugh:
Mounted one of the tyres on the rim and tried it on the car today there are clearance issues everywhere what a bummer my own fault I should have taken some proper measurements before hand . Really do need the 275/17's but there aren't any in the country . Looks like I might just have to put some normal 45 profile road tyres on the 17 inch rims I've got suppose they have to be better then the 19's and 30 profile .
I could have told you that. The only reason I ordered the 295's is because I can't get hold of 275/17's at the moment but looks like Rocket will have a shipment in next week after speaking to them on the phone today . One thing I can't work out is the M/t size chart the measurements don't seem to match up . They have the 295/45/17 equivalent to a 28inch slick and the 275/40/17's equivalent to a 26inch slick . Thing is I just measured my 295's and they are nowhere near 28inchs tall more like 26 and 26inches is still too big for the wheel arches . I would be interested to find out the exact height of the 275/40/17's.
Marko picked up his rubber today...even supplied him some coilovers.
They were out of Mark Jacobsen's GTR when it was running mid 8's on the same rubber so should suit the car just fine.
No excuses not to blast into the 10's now mate.
all onus on marko lol
well i do have no excuses actually
oh & thanks for the beer at your place paul :)
hi guys (& paul),
i probably shouldn't post this here but it seems that i am surrounded by knowledgeable guys on this particular thread so here goes:
I have noticed over the past week or so that my peak knock level on my power fc handcontroller reads up to 107, but only has occured a few times!
i then discovered today the reason my knock is peaking @ 107 is because when I start the car sometimes the power fc picks up a massive knock reading when im cranking the car! i monitored this today & repeatedly started the car as it showed this high reading on average every 5th start.
it sounds to me like the knock sensors are picking up sound from maybe the starter motor or when the starter motor actually engages the flywheel...weird huh...does anyone else have this issue?
another thing as well - if i take the car to redline when the fuel cut occurs will this also register a higher than normal knock level?
i had my car booked tomorrow for crd to check over but maybe this isnt required, i dont want to waste jim's valuable time.
regards,
Edited by Marko R1
hi guys (& paul),
regards,
when i ran a Power FC ialways reset the peakhold after starting engine for that very reason.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
