Ps3 2.40 Update
Pattygtst
 Share
Did anyone uodate there PS3 with e new update
Apparently there are alot of complaints about it turning there machines into useless bricks. Glad i haven't done it apparently it has been taken off see link for more info
http://www.ps3fanboy.com/2008/07/02/has-2-...update-servers/
http://news.teamxbox.com/xbox/16964/Sony-P...ed-PS3-Reports/
Edited by Pattygtst
Apparently its to do with the download servers. The updates aren't finishing properly and rebooting the console, and trying to install a half-finished update makes it crap itself. I downloaded it off the web and it worked fine.
My little brother did it without me knowing while I was at work...works fine and haven't had an issue with it...Same goes for all of my mates with their PS3's :D
the playstation website says a number of users have complained that the "XMB" (XrossMediaBar), is not displayed after updating to the PS3 2.40 update.
they have temporarily taken the update off until they fix the problem.
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
