yeah thought it was from ATP
bought the same turbo for a customer awhile back with the same anti surge compressor housing but with the .63 exhaust housing and the anti surge realli does make a difference if ur going to be using the .63 housing
what sort of difference are we talking? I have the .63 and no surge issues. boost control, shit yes, surge, no. I do have 256/264 cams though.
-33- also has a .63 IW. He hasn't mentioned surge either, just the boost control problems
good choice of tuner too btw Gary
Yes it's a funny thing Dave, some cars have surge, some don't. Cams will definately be on the cards for the future. I'm hoping that will reduce the overlap for more timing.
Yeah, I think Yavus is great, takes a cautious attitude to tuning. Don't you just get sick and tired of tuners that shake your hand then tell you to come back in the afternoon to pick it up ? I want to be there to tell them how far to go and make sure tune for drivability, fuel economy, safety and only then power.
I've been there every time my car has been on the dyno.
I don't know that cautious is the right word, but he is certainly very careful during the initial stages of a tune making sure all the basics are covered before starting to chase power.
I can guarantee he will push you to jam some boost into it. :P
Or maybe he just does that to me because he knows i'll let him.....
And I can guarantee I'll let him jam some boost into it. BUT, 270 is what I'm after so we'll see. Buy the way, I'm thinking peak boost on this turbo would be around 22lbs. The compressor map seems to indicate 17lbs as right in the meat of the turbo's potential. What do you think ?
It'll depend on the engine really. I couldn't run more than 21psi with my old setup before valve float, others have run more.
Because of the boost control problems i haven't really been able to push mine but it was making 255-260 pretty easily on 16psi. You may need a bit more boost as you don't have cams in there.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
