how much did your mate pay for his car?
stamp duty in qld is calculated at #.5% of the value, therefore you gotta pay $3.50 every $100 dollars you pay for the car.. WA prob has different rules regarding the stamp duty.. CAUSE THATS THE GOVT FOR YA
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3991355
Stamp duty applies to most assets that undergo a change of ownership, its a tax taken by the government to fund our country (in theory)
Im not against stamp duty but i think the amounts we pay are ridiculuous, if in fact the stamp duty is higher in WA its probably because less assets are changing hands therefore the premium is higher.
a drug dealer will add cutters and fillers to his drugs to build up its mass after a major drug bust hurts his profits.
btw: its noones business how much u paid for the car hence just put 'skyline coupe' on the transfer form and say u paid 12,000 for it rather than 49
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3991541
I cant, the invoice and transfer of the car is send from the import company.
If its a case of 3.5 for every 100, that would mean my stamp duty would be about 1700, yet its twice that, so is there any reason why the stamp duty in WA is this ridiculous?
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992231
I ran them up and they quoted me 3400, i used the website and it quoted me 3145 or something like that. Just very annoying seen as though my car is now unregistered and sitting in the driveway until i save up the required money (which is going to take a while).
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992432
I tried to look up some information, and by the looks of it when you go over the 40k threshold here in WA, things get a bit pricey.
On a $50 000 car the stamp duty in Queensland is $1 000, while in Western Australia the stamp duty is $3 250
Seems they have lowered the thresholds and increased the % here in WA while the other states are much cheaper. That's the government for you.
Edited by gersfan
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992523
the difference in price is prolly the gst they illegaly add on to the stamp duty tax
but didnt your importer inform you of all associated costs when you went to seethemabout importing a car ?
also only pay 6 months rego that will make it easier on the hip pocket for a while
i know mine did
Edited by gazza750
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992584
My car was 49k so wouldn't fall into that category. Also, while we are on the subject, i want to talk about compliancing. I know pod filters are illegal unless correctly bracketed down and shielded (by ARC box will eliminate this problem).
I also know that if there are no speakers in the rear shelf, you must replace them with replacement speakers or get them properly covered. Is this correct?
Lastly, i have an exhaust with Jasma plates attached and its not too loud, should this be alright?
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992629
Hmm, in Vic for compliance they remove the speakers and put little child restraint brackets over where the speaker goes.
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3992750
did the new labour government tax for luxury cars affect the stamp duty for transfers?? anyone check this?
if anyone wants to know, if you buy a car over 50k in australia you must pay a luxury car tax of 33% over the old 25% during the howard years.
The LCT threshold is actually $57,180 excluding any stamps or rego costs..
Edited by Duncan1
https://www.sau.com.au/forums/topic/226673-stamp-duty/#findComment-3995447
    • I like the idea of tagging the model, and if GTS-t/GTt or GTR, and then a what, so wiring, engine, suspension.   That way you end up with a matrix, all content R33 GTST, or you can find all content that is wiring related for example.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
