Hi Guys,
Currently have a castor issue with the car (R32 GTR) which causes it to pull to the left while driving
A shop has recommended getting adjustable radius rods but I've also been told that replacing the castor rod bushes should be enough.
What are the advantages of one over the other? Which should I use?
Cheers!
Edited by coakman
Adjustable bushes give a limited adjustment range, of the order of +/- 0.75 deg . Adjustable rods give almost infinite adjustment.
But,
road surfaces, in general, camber to the left. So, if you let go of the stering wheel, the car will drift left as gravity pushes it down the camber.
What exactly is the "issue" you have with castor?
But,
It's a GTR, the front drive shaft angle limits the amount of caster adjustment.
Cheers
Gary
But,
Car felt fine initially. Had a four wheel alignment after fitting new tyres to the stock rims. After that, I noticed a definite gentle pull to the left. Took it back to where the alignment was done and they confirmed that alignment was fine but castor was out and unadjustable.
Had the car serviced the next day and the place I took it to confirmed the castor issue (both bushes poor) as well as rhr cradle bush being poor.
On a nice straight, dead flat piece of road, if you let go off the wheel you get a nice 'gentle', but very definite pull to the left.
Edited by coakman
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
