Hi Lads/Ladies,
I am looking at buying a 94 Vspec dark blue factory stock car with 49000kms as a shed warrior. This is is described by my lads in Japan as brand new.
Just wondering what your thoughts are about somehting like this car being an investment (20+ years).
Cheers,
Ken
https://www.sau.com.au/forums/topic/226701-investment-vehicles/
I'd say being unmolested, it will lose less value in 20 years than a modified GTR (even one of the 600hp ones that seem to be fairly cheap these days). Let's face it - much as we may love them, GTR skylines are hardly unique, are they?
As for investment, you'd hardly call any car an investment. You can strike it lucky with some cars, and anyone who happened to own a mint GTR Torana, Phase 3 Falcon, etc. 5 years ago, will be sitting pretty today. That's more a function of today's economy than wise investment strategies.
IMHO, something like an aussie delivered R32 will actually have something unique about it, so will relatively be a good investment as far as cars go.
If you want to invest money for 20 years, then property, managed funds, Super, shares would all outstrip any automotive "investment" by an order of magnitude. Now's a pretty cheap time to buy into the share market.
QFFT
QFFT
You've taken laziness to a whole new level..
Cars as a long-term investment are a bad idea, who knows where transport in 20yrs will be..big oil burners might be outlawed by then.
Unless it was a true collectors/museum piece worthy of pebble beach type appreciation I wouldn't think it a wise move.
as opposed to your echo of the above?
I was just empahsising that the current so called "investment" vehicles are more due to the credit bubble we are currently in.
People are buying things with tomorrow's money, or debt or credit dependant on how you want to call it.
Cars included.
If you feel that it is a strong investment, good luck, but a biased opinion from Skyline enthusiasts shouldn't be the first or last place you get your investment advice from.
If you feel that gambling on an items future worth will pay off in the future, go for it, but asking people who are into the same type of car will only confirm your simple idea.
Ask a barber if you need a haircut, and I'm sure he will tell you that you do!
Easy tough guy...maybe I should have included a smiley, but I thought it was obvious enough.
Hardly an echo of the above, I don't see any duplication of thought or suggestion.
Anyway :P
feeling better?
Edited by madbung
The only reason I have had a look at the R32 (Vspec2) is that the good ones are going up in value now in Japan. I have also noticed the RS30's going throguh the roof too. I have a very soft spot for the 32's, I would like something that I could drive occasionaly too.
There is a Vspec at auction next week, grade 5A. Looks lovely.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
