I had a horrible week with the Ford Meteor which I have affectionately named the "Flying Gherkin" (you have no idea how bad I'm hanging to get rid of this piece of sh!t and replace with a real car!). Firstly it wouldn't start every morning and had to jump it. So I filled distilled water in the battery. Then it was makign this grinding sound and I realised there was this massive nail on the inner of the back right passenger tyre. Then it started overheating (in winter lol) so I drained the crappy coolant and put some fresh stuff in. I know its due for an oil change but I can't afford to take it to a mechanic and I don't have any ramps to do it myself (and no one I know has any). Now it's makign this constant sound thats kind of like a fluttering type of rattling. When I first got given the sh!tbox my ex unclipped the fan because it was doing something to the radiator (i wasn't really listening when he told me because I was playing ps2 lol) and I think that might be responsible for the noise. I have no idea what he unclipped let aloen what it does? I know it was to stop the fan running when the car was idle or something. Oh bugger I don't know, can anyone help me?
https://www.sau.com.au/forums/topic/226702-help-funny-noise-in-the-bunky/
  • Replies 45
lol
In my old car I could change oil without ramps, just need a decent oil catch tray, did it on the front lawn :)
Sounds like the cars got a lot off problems, just run it into the ground and buy another $100 bunky :worship:
It doesn't have problems =( my flying gherkin is just havign a bad week!!!! lol
but how the hell do you get under it to do the oil change? I don't have a front lawn! And I'll end up hurting myself....btw I've never doen an oil change before. I just googled it so I know what to do haha
Easier then, jack the front up, get oil tray, undo sump plug... dodge the black gold river.
Redo sump plug, fill right amount of oil back in, usually a nice big filler on the engines head- use a funnel or a cut 2L coke bottle.
Everyone's told me not to do that because it's dangerous?
lol, i did it on grass with a paver under the jack... I just made sure I stuffed something under the car near where I was working, like a spare wheel in case the jack fails.
Well thank god I have that spare wheel in my loungeroom.... haha just kidding...i think I'll get one of the boys to do it...I'm so not risking crushing my pretty face lol
Come on guys, where are your manners?
Mel, if you need a hand I'll help you out. I do it for a living anyway! I did mine without a jack, but then I lowered it so I cant do that anymore. But if your thin enough (I'm a stick :P) then its even easier.
Let me know
Awww I'm a pretty lady now am I? Haha And OI! I do get dirty with my car!! Last week I'd just had my nails done and I got a nail in my tyre so I changed it all by myself!!! And to prove it...I stuffed one of my nails up cos they weren't dry yet but it didn't matter cos my car could drive again!!! Aaaaand I ended up with black stuff on my face. I rocked up at my friends "girls nite" and they were like "melskis playing cars again" lol
So yeah umm...if someone could help me that'd be awsome! I'm in Yokine...
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
