  • Replies 45
Dammit... the noise has stopped.... now my car won't start without a jump! I've checked the battery filled up with distilled water and checked the leads... everything seems fine! It's all buggered!
I'm back in Perth late next week and unfortunately I have previous experience with a Meteor. If one of these fine gentlemen fails to assist drop me a line...I'm ten minutes up the road...At least you can change your own tyres. I had an ex who had a flat on her MGB and I had to drive 30 minutes to change it...damn centre lock rims
Ok....so update on the bunky!
To all you Einsteins who said: "Get a new car" thankyou for your highly intelligent, genious input....how ever, noticable to some, I am more than obviously in the process of doing this..so please stop hammering me with your overwhelming brain power!!
Anyways...more to the point...the bunky is now making a "shooosh" sound every nwo and then when I accelerate. I can't pin point any pattern, it just happens randomly. it soudns liek the exhaust, but it's pretty scary! Please help! I really need to keep this running to get em from A to B at least till I get finance!!!
Swooshing is fine for a ladies car, when it starts going brackata-brackata-pop-brackata-brackata-brack-pop-pop-kashung you're in trouble.
What do u mean for a ladies car....it's not a ladiescar it's a SH!TBOX? And swooshing is fine?....but it's never doen it before up until satruday....i swear it's comign from the exhaust when it first happened i thought I'd popped a tyre
Probably just as you described & it's an exhaust leak. Only a pretty bad one.
And sif edit my post at the top of the page!
What're u talkign abotu editing ur post? lol im confused....
And "only a pretty bad one"?? wellllll thank god for that! lol aw-ohz! I took a mate for a drive last night and he said he's not sure if it's the exhaust or not now. When I take off it does it for about the first 5 mins, and I can't accelerate and it like revs and slows down then all of a sudden the swooooosh noise stops and I can drive properly again....?!?!?! Any ideas?!!
Are you still trying to con some poor fella into mowing your lawns and painting the house?
Maybe time for a basic service, plugs, leads, distributor cap..ect could be in order.
Does it do it only when the engine is cold? does it have an auto choke or manual choke? Try letting the car warm up a bit on cold start.
Atleast pull the plugs out and give them a clean if you're on a budget, same goes for the contact points on the leads and distibutor cap.
Let someone else with more knowledge have a listen-drive. I will most probably be something very basic.
Unless of course it's going brackata-brackata-pop-brackata-brackata-brack-pop-pop-kashung :(
Haha Yes I'm giving it all I got!!! It's worth a try right? Some poor fella will fall for it! lol jkz
Thanks that helps heaps Yeah it's got a manual choke. That means I'd have to give it like 15mins to warm up cos I normally give it a good 10mins. I'll see how I got with all of that and no I want to learn to do it myself ;)
Thanks for the tips!!
  • 3 weeks later...
Just wanted to say thanks to everyone for giving me help & info about this. I have come to the conclusion that the gherkin is possessed. There is no longer funny noises and it's driving perfectly fine. I need to replace the battery. All of a sudden the radio has started working again too (which hasn't worked for 6months!!!) Now it's all stupid cosmetic damage (see: below). The front side panel was bent in by someone with a crowbar 9god knwos what they were trying to do) and my window lever broke so my Bushman Mechanic friend, Joel jammed it in place with some sticks on the ground (*face palm*) and one night the horn went crazy everytime I turned the wheel so in a fit of rage I ripped it out!
So at least now it'll get me from A to B until I get finance (i have an appointment with the bank 2 fridays from now and they're sure I'll pass this time. I failed last time due to an account overdrawl but 8weeks with no over-draw and I should be suh-weet!!!) So Yeah thanx Guys!!!
lol teh flying gherkin, i still dont get it
What are you planning on buying? car wise that is
umm....cuz it's green...like gherkin green.... ahhh forget it
Umm hoping for a 32 but probz just going to go with a 33
Guest
    • Hot tip, stop picking at shit. Live in bliss instead   From my recent experience in rust repairs, white it may seem to not go much further back, you'll still need to cut back a bit further.  From what I can see there, the outer skin, and the inner is rusted too. From what I can see you've got the inner one which is all structural, and window likely affixes too.   If tag Murray Calavera here, but my phone won't let me tag him, he'd probably be able to give the best advise.   I do know, welding roof panels is a right pain in the bollocks! Very heavy to heat distort the roof and warp it all.
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
