R30 skylines
rsx84
 Share
  • Replies 43
  • 1 month later...
hey rsx
just looking at your site, love the ironmask
how good does the rb20 go, looks like u runnin no cooler
as for those jap rims....i got no idea
would have to contact someone on that r30.co.jp site or sumthin
and see where they get their rims from
not my site, pictures are mine through, it goes very well those pictures are about 6 months old, i'm running a hybrid monster cooler now(icey).
no one has been able to help here in oz and one or to in jp. looks like i'll get some (not so legal) stud pattern changing spacers from JMS, they seem to think you can get away with them???
Hi,
Just bought a '81 HR30 L20E/5 speed. Chassis no. in the low twenty thousand, looks like a DR30.
Have a bid on an internet auction for a FJ20 with weber sidedrafts, thinking very seriously about improving the brakes & suspension, club racing it till the L20 expires, then transplanting the FJ.
Need all the suspension & brakes info. you guys have.
Cheers
Russ
im drivin a 85 R30, silver jap import Ti mint condition 190 000km, bugger the round taillights were taken off before it got to aus. im looking for a set in southern aus if anyone has any.
closely beat a VP commodore in a drag to 100km-only thing his was auto- the old skys are still sweet to drive.
im looking at getting a set of extractors+pod, are they worth the $$
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
