Why are you drawing in Photoshop...?
You should be using illustrator, more precise, not resolution dependent, smaller file sizes, easier to draw, better result...
Then you can convert it to photoshop if you really have to later...
I usually draw everything in illustrator, I don't find a need to use photoshop for any part of it, even show shading or reflections are done in illustrator...
Photoshop sux for drawing
I'd have to agree, i love Photoshop, its an awesome program, but Illustrator or Corel Draw will prove far more useful for this type of art, not only is the image sharper but its vector, so the infinite scaleability comes in handy for bg's etc... keep it up
Here is one i did nearly a year ago. a bit dodgy, some of the lines arent as smooth as they could be but it was just messing around, its a small pic, but have the original somewhere at home, i think i used illustrator, i wouldnt mind doin some more of these though, a little time consuming but look great,
nice work on the above might i add, and the last of the trucks looks to be the best!
Edited by RusH_
take your photo int PS and using the pen tool, run lines along the main lines of the car to give it its shape, start off with the parts that make up the shape of the car, ie: the main body, headlights, wheels etc... then move onto smaller details like the insides of the lights, indicators, and any other finer details until your happy with the end product.
you dont necessarily have to do them in that order, with practice you'll probably develop your own technique.
that is what i said in previous posts above...
the question was how do u do it in PS, hence i explained it in PS, that said...
its essentially, the process to create this type of art is the same in illustrator or PS or Corel
Edited by RusH_
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
