R32 Gts-t with R33 Rb25det engine and gearbox
Raws car
Auction grade 3.5 car
80,000 on the 25 package
motor was rebuilt with new rings and bearings before fitting 2,500km ago
VG30 op6 Turbo (larger rear housing same as r34 gt-t)
New Arp headstuds
New timing belt
Tomei 256 Intact cam
New Tomei 1.2mm metal headgasket
New front mount intercooler
New extreme heavy duty clutch
New D1 strengthend shifter (same through just more postive feel)
New Section rear camber arms
New Kts tie rod ends
New Ikea Formula tie rods
New Kenwood head deck
New Alloy Steering bush
New Nolthane Steering rack bushes
New front Brake pads
new clutch master cylinder
Ikea Formula Traction rods
Non Hicas S13 rear craddle
full exhaust turbo back
Apexi pod filter
Alloy craddle bushes
Buddy club front coilovers
G master rear coilovers
rear strut brace
R33 Gtr rims 17 x 9 +30 all round
Gtr fuel pump
all new fuilds engine oil, brake fuild, clutch fuild, gearbox oil, diff oil all changed 2,500km ago or less
Alarm , keyless entry
Price: $12500.00 ono
call me on 041 1152733 with any offers questions
Edited by 1400r
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
