R32 Gts-t with R33 Rb25det engine and gearbox
Raws car
Auction grade 3.5 car
80,000 on the 25 package
motor was rebuilt with new rings and bearings before fitting 2,500km ago
VG30 op6 Turbo (larger rear housing same as r34 gt-t)
New Arp headstuds
New timing belt
Tomei 256 Intact cam
New Tomei 1.2mm metal headgasket
New front mount intercooler
New extreme heavy duty clutch
New D1 strengthend shifter (same through just more postive feel)
New Section rear camber arms
New Kts tie rod ends
New Ikea Formula tie rods
New Kenwood head deck
New Alloy Steering bush
New Nolthane Steering rack bushes
New front Brake pads
new clutch master cylinder
Ikea Formula Traction rods
Non Hicas S13 rear craddle
full exhaust turbo back
Apexi pod filter
Alloy craddle bushes
Buddy club front coilovers
G master rear coilovers
rear strut brace
R33 Gtr rims 17 x 9 +30 all round
Gtr fuel pump
all new fuilds engine oil, brake fuild, clutch fuild, gearbox oil, diff oil all changed 2,500km ago or less
Alarm , keyless entry
Price: $12500.00 ono
call me on 041 1152733 with any offers questions
Edited by 1400r
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
