  • Replies 67
Posted Images
Why is it that when someone asks for opinions, and gets them, everyone has a cry about it?
If you want people to post telling you how good your car looks, then state that. Don't ask for opinions if you can't handle the fact that some people aren't going to like it.
looks awesome i was going to do similar thing with the same colours something like that i just used your car cause it is easier
Edited by Turbo 33
its one thing to give an opinion dezz. but carrying on about it like i rooted your sister then kicked your dog is another just get over it brother. cant we all just get along?
Edited by yup21t
Don't worry about it mate, there's plenty of characters on here... I am sure in time you'll meet them all.
GTST wasn't all negative, just take the good with the bad, we're not all gonna like it and some people will come off harsher than others, especially since it's a forum on the intartubes.
There's a wealth of knowledge on here so don't get scared off.
Cheers.
Edit: I always thought about going a black roof with carbon boot and bonnet on a white car, but I can never decide where to stop the paint on the pillars. Hence the roof is staying white.
Oh ninja edit for the loss. Should have quoted you... now I look like a tool! Dezz was all negative... lol, but he is entitled to his opinion as well.
I said 'I think it looks ridiculous.'
How is that carrying on?
Again, if you can't deal with the fact that not everyone is going to like it, don't ask for opinions.
Yup21t you dont have to keep appologising trying to make everyone happy, people are assholes
the quicker you realize the fact the better off you will be.
Personally i think your paint job looks wicked you did a good job
that would look good too i was going to marble it but always wanted a 2 tone car
Hey, you've got a skill - and it's part of your trade...
Have you ever thought of advertising that skill on your machine?
If you have your own business in this field and advertise it on your car, the improvements that you make on the wheels will be tax deductible !!
Keep right on going. And remember, only half a % in this world are fashion-setters. the other 99.5% are fashion-followers.
Cheers, Terry
Edited by Terry_GT-R34
Looks hot dude, I would do bling wheels with that paint, would look awesome.
Also I'd either smoke or remove those indicators...
With so many skyline around these days good to see something original, wouldn't do it to my car but still appreciate it.
Plus the new paint should give you a few more KW at the wheels........
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
