Can you bring back some of those Nismo S-Tune whole body & bonnet decal ?
You can get them here. Do a search in the cosmetic section. I've been thinking about it myself, but went to order and couldn't decide on which colour combo :D
I also think you should bring back a stack of clear indicators for the coupe the cars look so much nicer with them!
Got a blue one on the way like your avatar - has clear - looks sweet. Got a silver one coming as well without them so... want to fix that - US ebay sells them for 30 to 50 + postage :D
I've been here for 4 days now... Since I've been here for work I haven't really ventured out of the middle of Kyoto city.
the Skyline report card:
- 1 R35 GTR in the Graphite colour (HOT!)
- 1 R33 GTR with a carbon fibre diffuser kit
- 0 V35 Coupes
- 1 V35 Sedan and 2 V36 Sedans
That's it. I'm rather disappointed.
I've seen lots of LS460/600h, some CLS65 AMG, a G55 AMG, SL55 and Ferrari F355.
I also haven't been able to locate a Nissan dealer (my google searches are futile). Does anyone know the closest one to Shijo Karasuma? :D
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
