hello.
recent dyno run of my r33 gtst displayed rather inconsistent air fuel ratio readings. not surprising given the lack of a/m management despite the state of mods. (about 240rwkw)
ranges from 12.1 to about 13.0. my understanding is that this is rich, what i found on my searches was that something like 14.7 is ideal.
opinions?
i do hope its not in fact running lean. because i just havent quite got the cash for ecu goodness.
https://www.sau.com.au/forums/topic/226831-ideal-afr/
bear in mind that the peak power is only at about 5300rpm 13psi, because the coilpacks fried themselves and the test was aborted. the AFR at this point is about 12.2. i will take it back soon and wind it right out to 18 or 20psi.
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3993883
i'd be more worried about the shape of the boost plot( looks like that of a centrifugal supercharger), although it seems like your running out of fuel in the top end. your running standard injectors i would assume? seems like a big hump in the middle where it leans out, what sort of management are you using?
PS, how much power are you making? the graph says ~170 but you sy 240? your overall power curve seems a bit peaky also... more specs on your setup overall?
Edited by VB-
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3993931
theyre 440cc injectors i believe. i want to upgrade the fuel pump soon.
not sure what you mean in regards to the boost curve. i thought it looked ok except for at the end where the massive misfire wrecked the run. stock ecu. ive heard they generally run rich, so if its leaning out its because the injectors/pump arent big enough yeh?
it made 170rwkw at 150kmh, or 5250rpm. judging by the shape of the curve youd expect it to keep going up and make 230+ at around 6500 or so. remember the run was aborted due to misfiring.
kkr430 @ 16psi
injectors
greddy style ff plenum
3/3.5in turbo back
fmic
hks pod
atmo bov
'custom high-flowed' cat
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3993996
yeah you should be all in by about 4000rpm with that turbo. take a look at the plot for boost, it just keeps climbing and climbing till redline, it should shoot straight up as early as possible, then hold flat at 16psi till redline (ideally, you wont get it perfect but should be able to get it damn close)
has your stock ECU been chipped or is it just a standard computer? i would expect with all those other mods that its at least remapped, if not, then you've really gone off track buying all those other mods and this should be addressed immeadiately, without management all you've done is thrown away your money till this point. what size are your injectors?
1. invest in a fuel pump
2. sort out the boost issue, do you have an electronic controller?
3. get the A:F ratio flat at 12:1 till redline
4. get it tuned properly. i dont know the specifics of your mods and what you told your tuner you wanted done, but it really does seem like a rush job (dare i say it, a poor effort?)
did you ask for a tune or just a power run? if tune, who did it? (this assumes you got remap at least)
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3994282
what does that boost curve mean then? is it leaking? i agree its silly how late it reaches boost.
as far as i know the ecu is completely stock. i blew the stock turbo which took the engine with it, and replaced it with all that kit because i bought it all off a bloke as a package.
admittedly it is stupid, but i needed to get the car back on the road asap and so its not exactly an ideal situation.
as i said above, i believe the injectors are 440cc.
no i havent got an ebc, this along with fuel pump and maybe safc are on top of the shopping list. will an ebc improve the boost curve?
it was going to be tuned, but the coilpacks shat themselves. timed to perfection.
also, someone mentioned how can i run bigger injectors on the stock ecu. i dont know... why wouldnt you be able to?
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3994356
u wouldnt be able to run bigger injectors becoz u wouldnt be able to tune wit the stock ecu...
or the fuel pump module/reg would adjust but i dont c how???
and would the spray from the injector be all ova the place???
well i dont get it..lol
can some1 else try explain this?
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3994495
You need bigger fuel pump,Z32 AFM and PFC or remap ECU.
Std AFM is up to 300hp(220kw) max.
S-AFC can not handle Z32 AFM.
I am able to remap.
cheers. i will look into this stuff.
i checked out your topics about the remapping. sounds good. a lot cheaper than a pfc.
no one answered my question about the ebc though. will it improve the boost curve?
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3994641
The boost problem is in the stock engine management, i had a similar problem. Replace the ECU and the tune should fix it.
You can't run bigger injectors on a stock ECU because you have no way to rescale them. Its the same if you put bigger injectors on an aftermarket ECU, it still wont run them unless you rescale them which you can't do on a stock ECU.
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3994709
What type of boost controller are you fitting now?
Do you have boost gauge?
Normaly about 4000rpm max boost then come down.
If you come to me I will check for you.
id get one of the greddy ones. no i dont have a gauge, do i need one of those also?
while ive got you here, which fuel pump would you recommend? bosch 040/044, or the walbro in-tank or external? theyre cheaper than the bosch.
should i get a z32 afm before i come to you for remap?
thanks for your help, hopefully i can accumulate these parts over the next couple of weeks and come see you. do you install the pump/ebc/afm/gauge too? do me a nice deal lol.
...whod modify cars huh?
https://www.sau.com.au/forums/topic/226831-ideal-afr/#findComment-3995070
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
