Hi all,
Though I'd post up the conversion. I'm getting a R34 GTT sedan (it's the family car, pretty much stock, FMIC, pod, exhaust) converted to LPG using the vapour injection method (will be running dual fuel). Costing me about $5,200, then the gov rebate or $3,000. So out of pocket about $2,200 give or take (which if you use one of those online calculators, it would cost you almost the same in petrol for the 1st year, so 1st year no real saving, unless petrol hits $2, then laughing all the way :thumbsup: but after that, the savings kick in, and who knows how much petrol will cost in a year, even 6 months. WA gov has capped LPG until 2010 at 70c, i think it only goes up about 10c - 15c after that, so will take a while to get anywhere near the price of petrol. For anyone saying "if you worried about petrol, don't buy a Skyline" I'm not worried at the moment, but i'm trying to look down the line, when sh*t gets really expensive. Personally, i'd rather spend the money on moding the car, instead of keeping it running.
Not starting this till a couple of weeks, need to get the part ordered, plus the installer is away on holiday next week.
Only reason I'm posting this is cause the place i'm getting it installed said i can film the whole process, they also dyno & tune the car after, so i can get a print out to add to the vid.
The place in question are doing some crazy sh*t with LPG, they have a drag car their working on at the moment, once finished, is meant to be the worlds fastest dedicated LPG drag/street car (main reason i trust them, they know what there doing, i already have trouble trusting other people with our lines) and really nice guys to deal with. Nice to meet people who like to do things a bit different. :banana:
All we have done so far was work out where to put the LPG tank. We are losing the spare wheel so the tank can go in. We could have gone for dedicated LPG, i was not to fussed about losing petrol as there are so many places selling LPG now it's not a major problem, but would have ended up with quite a few under body mods to remove the old tank and add a new. More time & money. They will also change the spark plugs (need to anyway) and he said they can gap them at 0.7 (i have no idea what this is, i don't know sh*t about cars :yes: ) due to it being gas which would ignite easier (once again, i don't really know what i'm talking about, trying to remember what he said to me).
I'll update the posts when more things happen.
Steve
Edited by Noobs for Life
https://www.sau.com.au/forums/topic/226833-converting-a-r34-gtt-sedan-to-lpg/
whilst i do (and many others) wish you best of luck with it most are a bit cynical on LP gas
the usual known gotcha's distract many skyline owners away from it and most skyline owners accept the fact they will be paying a premium price to run their car
you buy a skyline for a reason, not an A to B car, so the usual fuel cost tactics dont always apply - hell i put 100ron in my r33 for the sake of it (and it reduces knocking on aggressive timing).
so good luck and hope its what you expect, make sure you are aware of the known gotcha's with LPG, they are covered on here, just search for "LPG" in the forced induction section.
Thanks paulr33, yeah, one of the 1st things i did was search here before i posted :) , i though i'd post incase any1 else was interested. i've seen a few other people have tried this, so why not, might as well, and i get an insiders look in to the process at the same time (there letting me watch them install everything, dyno & tune. That's the interesting part. Taking a day off work for that one, i think it's a good excuse :( )
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
