Hey guys,
Recently picked some gauges up. Oil Pressure, Water temp and Boost gauge.
Ive searched and got a DIY for the boost gauge which seems easy enough. So im kind of looking for info in regards to the other two.
Was wondering if you guys could give me a quick run down on installing and/or any extra bits i need? I heard i need to get a sandwhich plate for the oil pressure? If i do need this, any idea where i can get this from and approx cost?
What about water temp?
Since my car (r33gtst) already has oil pressure and water temp gauge, cant i just splice into those senders? Or will this stop the gauges in my dash from working?
Thanks in advance for the help guys~
Brendan
https://www.sau.com.au/forums/topic/226850-gauges/
hmmm brendan u need a sandwich plate for the oil press gauge china ones are like $20? but they're crap :banana: when i had it on my car the thing popped off while driving and leaked a sh*t load of oil out....because there wasn't enouhg length in the oil filter bolt thingy and also the cheap ones leak cause the rubber seal doesn't seal properly....or something but if u buy a G-reddy one for like $60 it'd be fine....water temp u need this tube looking thing that connects wiht u rradiator hose and u screw the gauge sender in it and thats it if u go on nengun and search it up it should be there :)
Cheers
Chi
https://www.sau.com.au/forums/topic/226850-gauges/#findComment-3994920
You can put a T piece where the stock sender is and run both from there, that's how I set mine up. (for oil pressure)
Did you get a water temp gauge from Jshop? I was looking and couldn't find one :D I grabbed me a water temp sensor housing though, they were hanging on the back wall.
Edited by bubba
https://www.sau.com.au/forums/topic/226850-gauges/#findComment-3996530
Hey guys,
Yep i got them for J shop, cheap as.
Intalled my boost gauge without problem yesterday.
I also picked up the sandwich plate...
And now waiting for my buddy club water temp adaptor to arrive. (Yes, i know getting branded prodct for such a thing is wasting money, but hey it will match with my nismo radiator cap and greddy air diversion plate ya! )
So when my water temp adaptor arrives ill install oil pressure and water temp.
Thanks for your advice! and offers to help me install them! Ill give it a go my self first, if i run into trouble, ill come knocking for help haha! :blush:
Im just a bit sad, that my 1500km old mobil 1 0-40 oil will be lost.. well some of it anyway, ill try and catch as much as i can!
https://www.sau.com.au/forums/topic/226850-gauges/#findComment-3998497
