I bought a cusco tension bar and tried to install it last night. I realised that the Trust sump extension gets in the way. If the cusco has a bit more offset to the front it would clear the sump easily.
Is there anything out there that has more offset than the cusco?
Duncan, I was hoping for an answer mate and not more question lol :P
Duncan, the tension rod bar is a bar that connects the 2 front mounting points for the 2 caster rods. It goes across the car. It sits roughly just underneath the front point of the oem sump. Unfortunately it does not offset far enough forward to clear an extended sump.
Right-o, never seen one and never thought I needed one! Have you been having issues with the radius/tension rod mounting points moving? because it is a very strong part of the subframe they are mounted to.
We certainly get tight clearance between the extended sump and sway bar when putting the motor in, but everything is OK once it is on its engine mounts.
bummer! I have the cusco tension rod brace on my car and i'm just about to put in the crate motor with trust extension. are you sure that you're not able to rotate it? my tension rod brace doesn't sit below the sump, it sits in front. and the trust sump doesn't stick out any further forward, just downwards.
I had 2 go at it aldready Beer and it won't fit.
I wish that someone can show me a way.
I found a picture on SAU of what we are looking at
As you can see from the picture the sump sits roughly inline with where the front mounting points for the caster rods are. The cusco mount into the inside bracket of the caster rod mounting points. These mounting points are behind the sump. The cusco brace is offset to the front. It will clear most of the sump extension but not at the top of the extension. It would be nice if the cusco has a tad more offset.
Dunc, I know of someone, who is very fast on this forum, had to reweld the caster rod mounting point. The cause of the break is certainly unknown. I don't know what caster rods he has either. One would assume this would break, from ripple strip or during transportation, rather than the front mounting bracket.
well...thats exactly what happened to my car. I broke both side caster rods in seperate incidents. no sign of damage or stress on the LCA or subframe mounting, both times the rod broke where the studs go thru to the LCA. the front caster rod mount is very strong but also I would think under less stress because it is the pivot/lever point.
I had a different issue. Mine cleared the sump but not the whiteline sway bar :)
gtst not gtr though
I gave it to a mate and it is now happily sitting on his s13 track hack in my back yard and it clears the whiteline bar on that :D
    • I finally figured this out. That green part, can actually be pushed out. Mine was on the wrong angle because I messed around with it. So what needs to be done is the clockspring to be removed (the loom can't be removed so you need to pull the cable towards you to remove it off the shaft then let it rest on something so it's not dangling) Then you just make sure that the 3 green dots form a triangle and that the 3 holes on the steering wheel inserts into the 3 holes on the green part (you need to push out the green part to do this otherwise you'll keep having the issue with the indicators not cancelling)
    • Welcome back, If looking for a quality workshop AK Racing are the go to for everything these days. No fancy socials or attention seeking just quality work and good people. Can do everything from general servicing to full race builds that do very well at local and international events.
    • Let me know how much you're looking to get! Thanks.
    • Oh very very true ! I'm honestly thinking about taking my entire R33 series 3 red stitch GTR interiour out of my car, selling it and buying a small house !  I spotted as pair of R400 GTR seats on GumBay on the interweb and they were asking around the 12K mark !
    • A few pop up now and then, but you're right, definitely not as often or as cheap as it was back then. Even non GTR seats are a joke these days, pretty sure you could have gotten one for a zinger box or pack of Winnie blues.
