R33 Circuit Car
Here are some photos of my r33 circuit car that i'm currently rebuilding.
Hi Roy i have the usuall stuff a RB 30 bottom end that gives me more problems than a 16 yearold school girl and ppg box mechanical diff alcon brakes i built it myself about 4 years ago and now i:m doing a full rebuild .
I like!!!!!!
I'll keep an eye on this thread so I can get more ideas for my 33 :P
Do you guys have any ideas on removing weight out of on my r33??? i started today with removing the steering column support bracket i think i might pick up 0.3 kg i guess i still have a long way to go .
This car is a beast when it holds together. If memory serves me it has runn 55's on the sprint circuit at QR. Get ya finger out George, You missed a great day yesterday.
Noel stop waving the carrot my shed leave pass has been reduced to just n3 hours a night but on a light note i;ve just finished changing my inner door skin and picked up 2kg;s and 1 kg on steering column mod.
Dont know if I've missed it anywhere - but what is the turbo of choice for this car mate?
Also - tow points - what are you going to use? straps or hooks? I can see the hole on the front bar - if its a hook, whats the best way and place etc to mount the hook to and with?
(n00b question alert :bunny: )
Cheers!
Chris
(n00b question alert :D )
Cheers!
Chris
Hi Chris; the current turbo setup is garrett gt35 it runs around 500 rw hp i have tried to4z on a previous engine great for horsepower but to laggy. at the moment i;m using tow straps on a sandwich plate seem to work i;ve been pulled out of the gravel trap at queensland raceway and it survived . :)
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
