Hi,
Im just about to install an ATI harmonic balancer on my RB26, and i was flicking through my engine (workshop) manual and discovered that there were two vastly different torque recommendations for the 30mm crank bolt.
There is an exploded view diagram of the RB26, and it has 446 - 544Nm (45.5 - 55.5Kg-m) with an arrow pointing to the crank bolt. However, when you read through the step by step instructions, it says "Tightening torque: 142 - 152Nm (14.5 - 15.5Kg-m)" in relation to the crank bolt.
My manual also has the instructions for the RB20 and RB25, and the recommended tightening torques are all 142 - 152Nm.
I cant see why the torque for the Rb26 should be any different, let alone almost 3.5 times that of the other engines. Its a massive amount of torque; that means you've gotta apply about 27Kg of load on the end of a torque wrench with a two meter handle!
Im wondering if its a typo in the manual, and the correct torque is the lesser of the two. If anyone could shed some light on this it would be appreciated; especially those who have had experience in installing these balancers on RB engines. Its a pretty important topic i reckon, as its an engine destroying problem if anything fails down there.
I wish i could supply some pics, but if anyone else has a manual could you verify this for all of us. I got my manual off a forum member who sold me a disk; i cant see why i wouldnt have originated from a Nissan maunual.
Thanks,
Shaun.
Edited by Shaun
https://www.sau.com.au/forums/topic/226987-correct-torque-for-rb26-crank-bolt/
Yeah, thats the same diagram as mine. You'll notice that in subsequent pages it recommends the 142-152Nm. It would be good to clear this up, as im a bit nervous about putting that much torque on the bolt.
Ive heard that you've gotta put the car in 5th and have someone with their foot hard on the brake, then use a stupid long handle to get the 500Nm. Apparently it sounds like the gearbox is going to let go under the load!
We need some engine builders to shed some light.
Shaun.
Edited by Shaun
Permanent Threadlocker + big breaker bar and hang off it is how I've always done it.
I drop mine in fourth gear with the hand brake on; never had issues with it moving.
I've always figured 4th would be the strongest gear 1:1; Don't like the idea of forcing 5th even though I'm probably only able to get 200-250nm in to it and no doubt the motor makes more at peak torque.
the last time i took the bolt out of my rb26 when i did the timing belt, it was on so fkn tight... ridicuous..
i put it back on and tightened to 156nm.... and then when the turbo popped and killed the motor... i STILL couldnt undo the bastard! lol
its like it tightened itself!
Why no threadlocker?
Doing mine up to basically as tight as I can. 200nm or so with thread locker its fairly easy to remove with a normal breaker bar.
Onyl reason I've used threadlocker is every crank bolt I've pulled has had some on it. Be it from factory I'm unsure; Multiple RB30e, 2 x rb20det's. Given the age I'd say they have all been apart prior.
im an engine builder and mechanic by trade
500nm+ is very wrong...
u would snap the bolt or the destroy the thread.. 142-152nm sounds about right and i wouldnt use threadlocker either
Im with you mate. Over 500Nm just sounds too much. I dont think my 350Kw engine even makes 500Nm of torque. Imagine if you snapped or stripped the bolt inside the crank! What a fcuking nightmare!
As for undoing it, ive heard that you can use a 300mm breaker bar and rest the handle on the radiator support, then crank the car (with injectors disconnected or something like that), so that the engine turns but the bolt doesnt. Do you think thats dodgy?
Anyone else with opinions or experience?
Shaun.
I would invest in a decent impact gun and compressor guys. You will end up using it for lots of other jobs so its worth it
That way you can even have the car in neutral and crack a bastard tight crank pulley bolt without the engine turning one bit. When it comes to tightening just a few seconds with the gun and its all done. Should always double check it with a breaker to be sure however.
I was thinking of doing it this way for my build. what PSI would you set on compressor? also would you use a torque wrench to test the bolt afterwards?
threadlocker?
cheers
rob
  • Like 1
there will not be many regular impact wrenches that can deliver 500Nm. some people use a special gun with a reduction gear to get the required torque. as for whether or not it's correct, I'm not 100%, but lots of people that I know, who are 'in the know' tell me it is. I do also know I've seen a fair few RB26 balancer bolts come loose, no doubt they were not tightened 'enough'. mine has been one of them. :P
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
