I was thinking of doing it this way for my build. what PSI would you set on compressor? also would you use a torque wrench to test the bolt afterwards?
threadlocker?
cheers
rob
What ever the air tool manual recommends (usually 90psi). I wouldnt use a threadlocker on the bolt personally. I mean, the nissan manual suggests you use oil which is the opposite of a threadlocker so if they feel confident that it will hold then so do I :P
As for the testing afterwards then yeah sure if you have a way to lock the motor then go for it. But knowing the strength of most decent rattle guns ide say you would be overtightening if you went any more.
I was thinking of going into Nissan and asking them if theyve got any info in this issue.
By the way, the new bolts from Nissan are $8.50!
Shaun.
Give it a go but every nissan mechanics are not exactly the pinnacle of brain power i have found.
I know exactly what you mean. Every time i go to Gosford Nissan for a part, they ask me for a fcuking VIN number! As soon as they hear you say 'Skyline' their care factor goes to zero. I actually quite enjoy pissing them off when asking for obscure parts.
Hornsby Nissan, however, are awesome. They'll do anything for you.
Shaun.
Strange, 2 pages down from that diagram, theres this...
Is that 446Nm for the crank pulley bolts?
Hi there, you all most likely know this already but for the record, the use of oil on threads of bolts to be torqued (to any value) is to avoid getting false torque settings due to "thread binding" before the bolt/nut has pulled down to achieve the stated torque setting. Regarding thread locker liquids, provided the threads (male/female ~ bolt/crank) are clean & free of binding media then I reckon liquid thread locker of the correct grade will do as a lubricant & provide some insurance after correct "pulldown" on this particular critical fastener. Thread lock compounds do not activate until all oxygen is excluded from the mating metal to metal surfaces. (thread faces) I refer to the Locktite range of products. Having said all that there are locking solutions in the Locktite range to do many different jobs, studlock/bearinglock/threadlock (several grades) select carefully.
Regarding the correct setting, the originator of the ATI harmonic balancer group buy is as stated on this forum getting his balancer installed by "dirtgarage", Red R racing?. Perhaps this fine gentleman could have the final say on the relevant Nm settings for RB25/RB26 before we start.
My 2c.
Cheers GW
PS: I absolutely hate drilling out snapped bolts/easy-outs. Even worse than housework! :D
My 2c.
Cheers GW
PS: I absolutely hate drilling out snapped bolts/easy-outs. Even worse than housework! :banana:
Bump.
And.........whether the crank bolt is left or right hand thread?
Cheers GW
I always thought the correct torque setting for the rb26 balancer was VFT?
Double hammer rattlegun at warp 4 on full charged air reciever? :( C'mon Mr dirtgarage, I think you could help & you owe me one I reckon.
Cheers GW
Cheers GW
Owe you one?...were you not the fella that accused me of lieing to you? Over the sale of a Power FC..Then i proved to you that i wasn't?....I think you may owe me one. (or was that someone else with a 260?)
150Nm with ARP lube on the bolt and both sides of the washer....then 1/2 a turn more with a piece of pipe over the torque wrench handle....So Duncan was correct...VFT
Why don't you ask Sydneykid?...he thinks he knows everything...lol
Edited by DiRTgarage
(150Nm with ARP lube on the bolt and both sides of the washer....then 1/2 a turn more with a piece of pipe over the torque wrench handle)
Is this for RB25 Sir? Or both 25 & 26?
Cheers GW
PS: Put the gloves away champ. I'm the guy that thort he was buying your fronts & dumps. My bad as I said then but I did wait patiently for you to make up your mind as to whether you were actually selling anything at all & at that time I did say that it would cost you down the track with technical information as my project progressed. (which were why I purchased your parts) I can post up the pm's if you like.
Peace brother, I will call on you again down the track no doubt.
Cheers GW
Sorry Graham...i DID have you confused with another 260 guy...my mistake. The guy i had you mixed up with is from Melb. with a very similar username. Actually it wasnt even that close..it was MyStag260
feel free to call on me anytime mate.
we did my crank bolt up VFT and it still managed to come loose and damage key way, and also bolt damage..
Autosport came to the rescue!
i think the rattle gun was on warp 10 that night and everything was very clean when assembled..
No worries & thanks for the info. I take it that the suitably lubed bolt/washer @ 150nm + 1/2 turn with enforcer bar (for all the ATI group buy guys) is for RB25 & 26
Cheers GW
Studlock it is then hey?
Cheers GW
+1 for the VFT torque setting..
the highest torque setting ive seen on any import that was legit is 300NM for 1 of the bolts in the subaru 6speed gearbox.. subaru supply there mechanics with a 3/4inch torque wrench that can do up to 600NM for that 1 bolt... f**king awesome tool! :thumbsup:
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
