Correct Torque For Rb26 Crank Bolt
Im freaking out about all these stories of balancers coming off now!
I got mine off fairly easily the other day. I tried cranking the engine with a 300mm bar resting on the radiator mount, but that didnt work. So then i fit my trolley jack handle over the breaker bar (making a 1 meter long handle), put the car in fourth with the brake on and really leant on it. It came off ok, but i could feel the stretch in the timing belt (i think thats what it was anyway). Just waiting for my ATI balancer to arrive now.
I think ill definately use a bit of loctite in the thread. Maybe the blue semi permanent stuff, rather than the red permanent.
Is there any point in replacing the bolt and washer if the original is undamaged? Theyre only $8.50 from Nissan, but i was wondering if the older (work hardened and stretched) bolt would actually be better than a new one that might stretch or move and maybe loosen as a result. Maybe im becoming over paranoid now.
Shaun.
Edited by Shaun
i have tried to get mine off and had no luck, this must be the hardest bolt ive ever tried to get out, i had a 1 meter breaker bar and was cranking the engine whilst the bar was on the floor, and all it did was lift the car....
im going to try cubes method, 4 gear, handbrake and massive massive 2 metre pole....
I usually use a square galvanised fence post/stake; only just slides over the breaker bar and is fairly easy on the hands as it has a flat surface. Then rock hard/bounce against it and before you know it its off.
I've also used a dewalt 18v rattle gun; removed the std rb20 one that was impossible to get off when the motor was out of the car.
So, when i go to do the bolt up again, am i right in thinking that i should use my 1 meter long handle and just put as much force on the thing as possible. When i say that, i mean put my entire body weight, swing off the bar type of force?
Im just trying to figure out how much torque up to 500Nm is. I mean, is it possible to snap gears in the gearbox, or break a timing belt, or strip the thread on the bolt or crankshaft???
Makes me shudder thinking about it. What do you guys reckon?
Shaun.
Shaun; You'll never break the cam belt as all the cam belt does is spin the cam shafts..
The rubber band feel is the driveline and most likely the IRS rear forcing the arse end down. Which is why I drop it in 4th 1:1 as I'm not keen on placing so much load through the drive line even though it should be able to handle it.
I've placed a hell of a lot of load on mine without breakage; the leverage I've had I had to shorten as it was hitting the bonnet. It should qualify for VFT :O
I've always hit the bolt with a wire brush to clean up the thread and then applied red loctight.
Ok, thanks Cubes.
Thats exactly what i wanted to know. Yeah, when i think about it logically, there's very little load on the cam belt. Feel like an idiot now, but it kinda looks like a rubber band, and thats what it felt like!
Shaun.
Edited by Shaun
Shaun.
Croydon uses a massive torque wrench, and unfortunately i was present when they did my torque bolt. It was a bit 'disturbing' to witness being done up. Teeth gritting stuff.
Childs play... i dunno why ppl do that shit for.. i did mine to 14xnm and ive never ever had any problems with it.. infact, when i had to take it back off again to build it, i couldnt.. had to get it off with the 1" rattle gun @ work..
500nm+ is just stupid and has nothing to do with how much torque ur car makes.. u could put the bolt through a 900nm rattle gun and ur driveline wont feel any of it
So your saying if you applied 900nm to the crank the usual single plate clutch would not slip? Or have I misunderstood. :bunny:
I think the problem is a fair amount have had their balancer come loose and let go. Most likely due to track use?
I know the torque of the bolt has nothing to do with the torque my car produces; i was just trying to put it in perspective.
Shaun.
Shaun.
If Mark Jacobsens GTR which has the most power out of any GTR in this country, that sees a lot of ignition cut rev limit and high revs, cannot shake a bolt loose using the same method as I described, then i dont think you will have anything to worry about.
Just use a moly based lube to get the correct torque when assembled. I wouldn't recommend Loctite or any other anerobic compound.
Edited by DiRTgarage
  • 11 years later...
How about just go off the 440 - 466 Nm as is in the manual ? We use an rb26 starter motor that is cut in half and welded up locked to lock flywheel and a 3/4 inch drive torque wrench, and go to 460Nm. Pretty easy when flywheel is locked properly,
And the right length torque wrench.
yes it is when all other rbs are around 150Nm. You'd be surprised when doing it that its easy to get to say 200Nm, then to get to the 460Nm it was around 1/4 of a turn more. Took notice the last couple of times to confirm this. Hardest part is getting a good quality 3/4 inch drive torque wrench as they are worth heaps.
  • Like 1
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
