Hi everyone, Running a GenT1000 kit on a LS1, having a drama making boost. ive checked all cooler piping and vaccum lines, checked rear wheel on turbo (T51R garrett) and thats fine. next to check is wastegate (bugger of a spot to get off just to check) ive changed bovs out incase they were staying open, but there not.
Problem is its like its struggling to make boost, ive turned boost controller off so it will run spring pressure ( 7psi ) and is only making 3psi. has anyone heard of the tial 44mm gate having dramas like this? if the spring broke would it make more then 7psi boost or would it make less?
Thanks
ps: i tried the search button also :P
https://www.sau.com.au/forums/topic/226990-struggling-to-make-boost/
Ive discovered that the spring pressures arent really what Tial say they are. I mean, i had a 15psi spring and was making 19psi, then i changed to a 7 pound spring and was making 11 psi.
You'll also notice that the spring rates differ between the GCG Turbos website and Tial USA website for the same spring. For example a large yellow on GCG might be 7psi, but on the us site it'll say its 10psi.
Weird.
kinda what happen to me mine was only making 4pound lol so i took it somewhere apparently my timing was out shit loads and the computer was putting the pounds down coz thats what it was safe to run well thats what the computer was doin
lol, shouldn't you be at www.ls1.com.au?
Or are they too bogan stupid over there to help you?
it isnt engine based problem, people on here a running tial setups aswell as big turbo's. didnt post here to start shit, i came here because most of you would prolly have upgraded turbo setups. Internal gated turbo's are most common with ls1.com.au.
Weird.
thanks for the reply mate. i might just rip the wastegate out and have a look and see whats happening inside it. ive emailed tial and awaiting there reply regarding the issue aswell.
thanks for the reply also mate, boost controller doesnt run with the engine management, 2bar map sensor sorts out timing, pressure and fuel etc.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
