SAFC fixed my problem, dyno!!
i got an extra 130rwhp by adding safc and having the car tuned at SST, as others have said all my mods made the car slower untill it was properly tuned, from 130hp @12psi to 253hp@16psi (it also made 224@12psi) cant be happier
  • 1 month later...
Redusing the gap of your plugs helps run smoother at higher revs
because the spark has less distance to jump standard is a gap of 1.1mm. Good idea to regap them if uping the boost. there probbly is a slight power gain to but the main thing I noticed was the overall smoothless of the engine at high revs.
Originally posted by FLY-SKY
so how do u gap ur plugs?
is it just diff plugs or wat?
i realli dun have a clue when it comes to this gappin plug thing!
and thanks for the info!
I've got Platinum 1.1's.
Yesterday I bought a little tool which basically has bits of metal in varying width, you insert this bit of metal (e.g. .08 width) in between the end of the plug and wack it(carefully) on something till the gap is narrowed.
I think you mean a Filler guage.
Originally posted by skylineakt
Hey Robo, nice power gain mate.
Your car must feel better now.
Just a silly question tho, if your car was originally running rich, by upping the boost wouldn't it pump in more air and making it a bit leaner??
Yes you are correct, but the AFM feels this and it tells the computer to richen it up more, so hence more fuel again. My original dyno graph shows the Air/Fuel ratios in the 10 and 9 to 1 which is extremely rich when the aim is for around 12 - 1. Currently im experiencing a little detonaiton at the top end of third gear which would probably is for the stock intercooler and/or lean mixture. I think i will be back on the dyno soon.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
