the series 4 rx7 compressor wheelis 51 mm the series 5 one is 54 or 55 mm and they are steel I ahve driven an r32 with this turbo set up with a t4 front wheel worht some though.
btw still ahvent fittted that turbo waiting for the ceffy to come back. also detonation could be because of a lack of fuel have you upgraded injecotrs and afm?
cheers
meggala
when will it have full boost on the RB20, and is it responsive? thanks meggala
  • Replies 221
sprint32, a smaller comp wheel, would reduce the chance of surge and also lower potential power. I went for the TO4 Vtrim as it is the biggest and highest flowing that will fit in the standard comp cover. Increasing the waste gate flow will always reduce back pressure, the trick then with the turbine housing is to not have it to small and inturn boostin to early and causing surge. The rotating mass with the ceramic turbine is very small and has extremely quick spool up. Hence why so much air has been allowed to bypass.
Guest Jordy32
BOOSTED- sounds like you ahve a winer with that turbo,
after reading that after you grooved the comp cover that the surge was not present at all.
making me belive that you would be able to reduce the vg30 rear hsg from 53mm to something like 47mm & have better boost response & still not surge.
i know this question has been asked before but do you think that a std rd20 turbo could have that same mod carried out???, ofcause you need that turbo with the thick shaft.
the sr20 Turbo has a t25 flange. The Vg30 is has a t3. I am not sure about the bearing housing. The same theory could be used with a larger compressor and enlarging the waste gate and or increasing turbine clearance to increase flow and reduce spoolup to get past the compressor surge zone. The sr does not have a ceramic turbine so increasing the turbine outlet would quicky reduce spoolup hence not providing as large gains from reduced back pressure....which in turn would limit compressor size. So in other words It may not be worth the hassle with only small gains viable with acceptable lag. Only one way to find out =)
I'm just curious thats all and i didnt fully understand the exact procedure thats all. Cause i just bought a vg30 bb turbo recently so i could do these mods on it, and i was advised by garrett not to pull the turbo apart cause i might brake the exhaust turbine etc etc..
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
