sprint32 Posted April 14, 2004 Share Posted April 14, 2004 Sweet.... any news on your plans for water injection. I'm a huge fan of this idea, I want to try it on mine when I get it back on the road. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781605 Share on other sites More sharing options...
BOOSTD Posted April 14, 2004 Author Share Posted April 14, 2004 I am working on water injection right now. I set up intercooler sprays last night and ran 112mph with it on and 107 without. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781611 Share on other sites More sharing options...
Guest INASNT Posted April 15, 2004 Share Posted April 15, 2004 Did u have the spray on for the whole run? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781624 Share on other sites More sharing options...
BOOSTD Posted April 15, 2004 Author Share Posted April 15, 2004 No just whenever I got time to push the button between gear changes, to much to thing of having to turn my thermo's off aswell. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781662 Share on other sites More sharing options...
Steve Posted April 15, 2004 Share Posted April 15, 2004 what sort of times did you manage Matt? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781711 Share on other sites More sharing options...
BOOSTD Posted April 15, 2004 Author Share Posted April 15, 2004 Blah...... nothing special. 2.3 60" will do that. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781716 Share on other sites More sharing options...
Guest INASNT Posted April 15, 2004 Share Posted April 15, 2004 Boostd With your intercooler spray are you using the rear window spray motor as power source and 1 or 2 nozzles? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781721 Share on other sites More sharing options...
BOOSTD Posted April 15, 2004 Author Share Posted April 15, 2004 yep, exactly. took ten minutes to setup. I only used one jet. will be setting up 3 in the future and an anti-drip valve... grrr Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781732 Share on other sites More sharing options...
2rismo Posted April 15, 2004 Share Posted April 15, 2004 and an anti-drip valve... grrr I'm running two that come on on a very hi-tech and up-market human-switch (rear window washer). 2 x garden variety (literally) sprinkler mist jets, some plastic washer tube and the plastic one way valve out of a mates water injection. He doesn't need it....I think.... Works a treat when I remember to use it... Adrian Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781914 Share on other sites More sharing options...
Guest INASNT Posted April 15, 2004 Share Posted April 15, 2004 yep, exactly. took ten minutes to setup. I only used one jet. will be setting up 3 in the future and an anti-drip valve... grrr r u using the rear washer switch or have u hooked up a new switch? Do u have a water return to the washer bottle? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-781921 Share on other sites More sharing options...
EnricoPalazzo Posted April 15, 2004 Share Posted April 15, 2004 hmm sounsds like a thing i might mess with. i was reading somewhere ages ago, that they recommend spending a little extra and by brass fittings over plastic as the spray pattern is meant to be very improtant in heat dissapation? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-783685 Share on other sites More sharing options...
BOOSTD Posted April 16, 2004 Author Share Posted April 16, 2004 r u using the rear washer switch or have u hooked up a new switch? Do u have a water return to the washer bottle? I used the washer switch at wsid, will be making a new switch on the w-end. Instant: I don't have water returning... Dean: you are the biggest copy cat ! I will call you "mini matt". Your turn to do something I can copy.....maybe not the sticky taped boost gauge line though. lol Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-784376 Share on other sites More sharing options...
NINOBROWN Posted April 16, 2004 Share Posted April 16, 2004 Does anyone know what size is the exhaust snout on a standard series 1 R33 turbo? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-785689 Share on other sites More sharing options...
BOOSTD Posted April 17, 2004 Author Share Posted April 17, 2004 47mm Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-786325 Share on other sites More sharing options...
benm Posted April 17, 2004 Share Posted April 17, 2004 I thought that FMIC Water Spray was just a rice thing... does spraying water on the fmic really make that much difference to temps for only 12-14 seconds? Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-786420 Share on other sites More sharing options...
EnricoPalazzo Posted April 17, 2004 Share Posted April 17, 2004 well sti install them on the wrx's so u think it would do somethin. matt: hehe so true mate. hey the boost gauge tape is da best bro. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-786622 Share on other sites More sharing options...
BOOSTD Posted April 17, 2004 Author Share Posted April 17, 2004 lol....bro Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-786717 Share on other sites More sharing options...
NINOBROWN Posted April 18, 2004 Share Posted April 18, 2004 If i was to do the same modifications on my standard turbo, would i get the same amount of power as doing the same thing to a vg30 turbo? considering that the vg30 has a 42mm exhaust turbine and the standard skyline turbo has a 47mm. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-786961 Share on other sites More sharing options...
BOOSTD Posted April 18, 2004 Author Share Posted April 18, 2004 opps my bad, VG30bb and RB25 are the same 42mm not 47mm. The VG30 would still make more power tho due to less back pressure with bigger A/R exhaust housing. Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-787073 Share on other sites More sharing options...
NINOBROWN Posted April 19, 2004 Share Posted April 19, 2004 thanx for the info, i was just trying to make sense of this all. cheers Link to comment https://www.sau.com.au/forums/topic/22706-350-turbo-made-253rwkw-9bar/page/6/#findComment-789854 Share on other sites More sharing options...
