Hi, most of the Rays wheels seem to be 19x9.5 or 19x10.5
The 10.5 inch wide ones are NOT street legal in NSW (more than 1 inch wicder than stock wheel)
So, do the 9.5 inch ones sit wide enough, ie: flush with the guard or do they sit too far in? Can you get an offset to sit wide enough in 9.5 inch?
Thanks
You've got a wide choice of offsets with Ray wheels. Check out their site and see what's available. Once you have a list of the offsets for that width in front of you, learn how to use the offset calculator (if you haven't already) and see which offset will make the wheels most flush with your guards.
Sorry I can't help any more, I'm not familiar with R34 GTR guards.
Edit: The standard wheel sizes are 18x9 with an offset of +30. Going wider with the same offset will give you a small guard clearance and inside clearance. Lower offsets will result in wider stance (if they both were the same width).
Just play around with the calculator and measure how much guard clearance you've got. Also don't forget to think about tyre sizes.
Edited by adam-__-
9.5" +12 (LMGT4 or TE37 are 2 examples in this size) will sit well in your guards.
10.5" +15 or +18 are a bit better.
Use a wheel offset calculator to see the difference (google).
Your stock R34 GTR wheel size and offset is 18x9" +30, but they sit way to far inside the guards IMO. You need to come out about 25mm to fill the guards on the stock wheels.
Thanks
I wouldn't worry about legality and rim width. Technically 19x9.5 +12 aren't legal either because they increase the track (outer measurement from the edge of the two rear tyres). You are definitely not likely to get busted for either because its too difficult for cops to remember and also its not 'top of mind' when defecting someone.
The only way to be legal is to have sunken battle ship offset which looks really crap (like stock) and 1inch wider and bigger rims. In which case you will look like you bought your rims from tempe!
Volk Racing have a new 19X10 inch 'Gold Tuning Fork' style out there. Series R30 I think. Good size dish and gets just to the guards of a R34 GTR with 265 tyres.
Should be on HJC Sports website.
  SRB_empire said:
should have gone 10.5 +12 much much better looking, i have them in te37 on my gtr :rofl:
Cant be bothered to get defected for having them to wide. The cops are stringent where I live.
9.5 +12 with 265's will still look the goods
Edited by Bakes
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
