hey all,
as the topic states my dipstick keeps blowing out. has anyone ever experienced this?
i had a quick search and nothing came up, also another thing to add is one of my belts is squeeling real bad when i go full throttle, i just had the belts replaced, was thinking that maybe my oil pump is seazing up causing the belts to squeel and excess pressure in the oil gallys,
the dip stick has blown out 2 or 3 times now, its annoying as my engine gets covered in oil everytime it happens, could someone please shed some light on why this could e happening
thanks
mitch
EDIT: forgot to mention its an R33 GTS-t
Edited by weeman1
https://www.sau.com.au/forums/topic/227068-dip-stick-blowing-out/
had this problem alot... at first it was because my catch can was setup rong.. so sort out your breathers and check if theres too much gunk built up in your rocker cover breathers and baffles...
The squealing on full throttle may be your exhaust manifold gasket.. Thats a common cause that alot of customers complain about when they say "belt squeal"
Also get a leakdown test done and a comp test done.. Because another reason may be too much positive crank case pressure, eg: rings are rooted, ringlands broken, pistons melted.
So thats a rough guideline to follow..
yeah exactly as above, my experience has been that its either
- catch can incorrect
- your engine is f*ked
i'm hoping for your sake that you have recently installed a catch can
if not, its time for a compression test and leak-down test and bring your wallet..
WOW, thanks for that fellas, would never have picked the squeal to be my exhaust manifold, my mate keeps telling me it sounds like ive got a leak there.
LTHLRB: no i dont thrash my car really, im lucky to hit full throttle once or twice a week, ive only got a 5 minute drive to work now so the car probly doesn't even warm up properly anymore, but the problem started about a month ago before i got this job. for the last year ive been doing 100 k's a day up and down the freeway
ive been running 10psi since i got the car, previous owner was running 8, at 10psi it creeps a little to 11psi
with the squeal i thought it would be the belts cause it does it on start up occasionally
does anyone know any good workshops around castle hill/baulkham hills? ive only just moved down here so im still new to the area
yeah i had this problem as well when i first got my car, it kept blowing dipstick out it was caused by a stuffed piston had a hole in it.
is your car still running on all 6? if it is it could be worn rings. Hey if ya want to ya could do a compression test ya self and buy a compression tester from autobarn or supercheap one what screws into your spark plug hole. all ya need is that a pen, paper and ya normal tools to get ya spark plugs out.
If ya want to check if ya piston rings are worn is to put a drop of oil down the spark plug hole, thats called a wet compression test it helps seal in the combustion pressure. good luck man hope its just ya catch can
thanks LTHLRB, what do you use to lube the belts up with? im going to do it this weekend, its too dark when i get home during the week
madevo3: how much is the compresion tester to buy? i think it would be a good investment
ill be checking my rocker cover breathers aswell, i hope thats all it is
thanks again for your help
hi, well i tightened up the belts, that seemed to stop the squeeling, also i found out i have an exhaust leak, im not sure if is from the exhaust manifold or the dump pipe, is there an easy way to tell?
also where would i get the gaskets from? i think i might just change them all
cheers
  • 3 weeks later...
sweet thanx, i thought you could get them there, just wanted to make sure,
when you say they're not cheap, how much do you think they will be?
Don't worry about the gaskets until you find out if you need a new engine.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
