I have seen that these cruises have been very successful in other states. I was wondering if anyone would be interested in trying one out? As i play soccer fri nites, and work all weekend, im always missing out on the fun...
12.00am Sat 24 aug (ie sat nite)
LIST:
EnricoP me
MadGT4
9krpm
MattR
Pawley
Miss Nismo
GFXman
Cyrius
Maxx
Cheeky32
Munro
Boostd
nismostu
Timmmmaayyyy
32godzilla + Others
PHAT 33 + 2 Others
https://www.sau.com.au/forums/topic/22709-midnight-cruise/
  • Replies 212
Originally posted by BOOSTD
We don't have the same law that the driver has to be identified before prosecution. Number plate is all our cops need.
Wierd thing happened about a week ago. I got home and about 5 minutes later coppers arrive at the front door. Asked if I was driving the car (wifes), I said I was. He then told me that the car was unregisered for about 3 weeks, and that they found out because they did a random rego check. He then told me that he couldnt book me cos he didnt actually see me driving, but please make sure the rego gets paid before taking it out again.
Maybe I just got lucky cos it was a newby copper?
https://www.sau.com.au/forums/topic/22709-midnight-cruise/#findComment-488390
Originally posted by cowboyb
I would do a dawn run if anyone's interested. Say 5am, while its still dark...down to Victor Harbour?!
I wouldnt mind joining a midnight cruise.. but i wouldnt recommend heading towards victor.. well not during this month anyway.. there is a huge police campaign along the adelaide to victor road.. so wouldnt be the best route if wanting to avoid police..
newayz.. sounds like fun..:)
https://www.sau.com.au/forums/topic/22709-midnight-cruise/#findComment-488500
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
