Very keen to sell my truck again. It's been for sale now on and off for 2 years! lol. To be fair I never did really take out any ads or anything other than SAU.
This truck has done under 1,000kms in the 2 years I've owned it. I've used it purely to move house a couple times and move some big parts around etc. I'm about to use it to move house again and now really want it sold.
It has FULL service history from brand new. Is in outstanding condition, runs like clockwork every time I need it. The only thing I've had to do to is is recharge and replace the batteries I keep letting go flat from lack of use. It also has great aircon which is lacking from a lot of commercial vehicles. Don't know what else I can say about it. It's very easy to drive, just regular 5 speed box, nice power steering, has switchable exhaust assisted brakes too for when you've got a load on or turn it off when you want to keep the noise down. I really can't fault it in anyway, but I just don't have space or money to keep it any more. I now have 6 cars and 2 motorbikes and need to sell something off badly.
Rego is due for renewal this month so it'll have 6 or 12 months rego on it and be ready to rock.
ASKING PRICE NOW DOWN TO $15,500. You would be lucky to buy the pantec for that much, let alone the truck under it...
  • Replies 51
Posted Images
Hey Charlie, the pantec is about 4 meters long and 1.85m wide, ceiling heigt inside is 1.75m. Length overall is 5.4m and height overall is 2.4m.
  • 8 months later...
  • 2 months later...
Hey Richard
What's the engine code on it?? I know Nissan put td42's in some of there trucks but as you said if it was built by Isuzu then it's prob got there engine in it
Hey Richard
this pic shows a nissan td42 http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=173716
  • 1 month later...
yeah it's a TD42. just fired it up again the other day and put 12mth more rego on it. truck is running nicely. I hadn't driven it for more than 6th months but it started instantly and runs just as sweetly as always. with a full 12mths rego on it now would be a good time for someone to buy it.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
