  • Replies 92
Posted Images
hey mate do you have the wiper de-icer switch or rear demister switch from the dash? (either sides of the steering wheel)
also, im desperate for a spare wheel cover in grey?
will pay postage
rear suspension, no.
ash tray and surround, no keeping for another project
switches, yeh i dont remember selling them but they're not in the dash anymore... so they'll either be on the floor of the car or in the shed somewhere. ill have a look as soon as i get a chance. i'm keeping the floor panels for now.
D.
D.
really really desperate for the spare wheel cover in grey!!!!! any luck on that?
also do you have mirrors? need both elec mirrors too
cheers
yeh i have both mirrors in white, $50 each.
do you mean the floor panel over the spare wheel or the grey flimsy thing under it that sits on the spare?
D.
D.
the floor panel over the spare wheel. previous owner cut mine up ready for a subwoofer install!
yeh nah i'm keeping the floor panels for now.
i only have 1 spare bag hook and i'm keeping it!! no light cover either
D.
AH, so *that's* what they're for!!
Do you have the roof handles, the ones that the cargo net clips into? I need the passenger side one, but will take both if you have them, as long as there are no broken clips... $40 posted to 5159? Thanks
Lol thanks. Actually if you haven't removed them yet, do you mind waiting a few days anyway? If you've already removed them that's cool I'll still get them anyway.
cheers
DaveB
Edited by DaveB
its all good mate, just spoke to my mate (mechanic) and its the tie rod ends i need which are pretty commonly available, and the seal i should be able to get froma bearing place up here, thanks tho mate :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
